• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Daz 3D Forums > 3rd Party Software > 3ds Max Discussion
Prop Creation in 3DS Max - Best Practices
savagestugsavagestug Posts: 200
November 2022 in 3ds Max Discussion
Can anyone point me in the direction of some sources for best practices tutorials for DS prop creation in 3DS Max? I'm looking to create props with morphs and multiple surfaces. Not looking to transfer figures from DS to Max.
Thanks.
  • vectorinusvectorinus Posts: 138
    November 2022 edited November 2022
    First you create some object in any 3d application. Then export it to obj format. Launch Daz Studio and import this object into the program. Details (for Blender) here:
    Your prop is in the Daz Studio now. Morphs for it  are created in the same 3D application (the object is morphed by the tools of your program). Then the morphed object is also exported to obj file.
    But now you don't import the object into Daz Studio as usual. You have to transfer it using the Morph Loader Pro plugin (with your prop active in the scene, of course). Details at the end of this video:
    That is, the first obj file is your prop, and the second is its morph. The number and order of vertices must be unchanged, otherwise the Morph Loader will not accept the morph object and will report an error in the log file.
    Post edited by vectorinus on November 2022
  • savagestugsavagestug Posts: 200
    November 2022
    Thanks, I have already seen those videos, and they were helpful. I am more looking for modeling best practices for models to be exported to DAZ. All quads, or tris OK? I'm curious, as when I try to make changes to models in DS I frequently run across what I thought was undesirable, namely lots of really long, skinny tris. None of the tutorials I have been able to find address this question.
  • MattymanxMattymanx Posts: 6,997
    November 2024
    All quads is prefered for DS content creation.  But dont worry if the shape needs triangles here or there.
  • gregsgraphics_cafd0962a0gregsgraphics_cafd0962a0 Posts: 114
    June 2025
     Long skinny tris are a no-no in any 3d software, not just DS.  Ngons are also not desirable because of the way they could triangulate after exporting.  Keep away from those two things and try as much as possible to keep a logical quad-based topology whenever possible.  Triangles are ok, but should be kept to a minimum only in areas where they are unavoidable or will not create pinching or artifacts in a render when smoothed (subdivided).  3dsmax has many good tools to keep everything quads, so you should be ok.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
