whats going wrong with this HDRI
Ive been trying to get Orestes Iray HDRI Environments - Autumn Hills to work but all I am getting is a blur (see attached pic) stating with a new scene clicking on autumn farm 01 and the camera 01 thats all I can getting no settings i can change make it any better  though its quite easy to make it even worse I think I must be doing something wrong but no idea what that might be  any help would be much appreciated
  • FishtalesFishtales Posts: 6,223
    Looks like you are using the DOF camera. Either turn it off for that camera or use another one.
  • DaveDave Posts: 207
    thats what i thought it looked like but dof IS turned off and its the same when i creat another camera
  • That's the default Ruins hdri that gets loaded in when you either create the environment/tonemapping nodes, or do an Iray preview. You can see the thumbnail for it on the right of your screenshot where it says Environment Map. Try clicking on one of the Autumn presets again to see if it loads in, the thumbnail in the Environment Map should change.
    Ah I see now thanks
