socks
Hi , does anyone know if there are socks where you can have one of them on and the other off ? and a pushed down/scrunched up moph/pose like they are falling off. for g3 g8
Post edited by andrushuk1 on
I was looking in Aeon Souls catalogue as they have some undress products, but they seem not to include socks.
And I am not aware of other products that can do it out of the box.
Some methods I can see if you just want one sock falling down.
A) Use mesh grabber to pull the upper part of one sock down
B) Use a D-former to do the same
C) Applying dForce to the socks and then weightpaint it to only the upper part of one sock. I would also increase Expansion-Contraction to 110-120.
If you want one sock on and one sock on the floor, I would load 2 pair of socks, hiding one sock in each, so one sock is on the character and the other is not and then simulate the other to lie in the floor.
It might be easier to export the socks and remove one in a modeller, and then import it twice.
Thanks Felis good ideas. :)
I think CJs Morphing Socks can be at least pulled down, scrunchy and stuff. There are lots of morphs included.
https://www.daz3d.com/morphing-socks-for-genesis-3-and-8
https://www.daz3d.com/tube-socks-for-genesis-3-and-genesis-8-female-s
but Felis's suggestions are also good , that way you can even create your own morphs for later use
The socks in this outfit are scrunched down. You might want to change the textures, of course. https://www.daz3d.com/on-the-beach-60s-outfit-for-genesis-8-males
Thanks SF-Design and lou_harper for the suggestions , I've put them in my wish list .. :)
You are welcome @andrushuk1
On Renderotica there are some good socks, the soccer socks have scrunching morphs and the long high socks are very good too.
this outfit has a scrunched sock
https://www.daz3d.com/dforce-granny-nightgown-outfit-for-genesis-8-females
