daz4-21
I have installed Daz4.21pro on my new PC running Windows 11. When loading I get the daz icon in the taskbar. When I click on it I get a little flash which disappear to the left from the screen. I have reinstalled Daz a few times now. My other software does not have this problem. Hexagon, Rhino3D, Meshlab, Meshroom etc do not have this problem. How to solve this problem.
What security software are you using?
Thanks for your reaction. I am using Brave at the moment. I have reinstalled it and did a restart. I do get the first screen when loading Daz. If I right click on the icon in the taskbar I see which files loaded last. From there I can load a file.
Daz then loads the file and looking at memory used by Daz it went up from 330 to 5000 Mb. Including telling which files are missing. I use a RTX 3060 Ti grafics card.
Regards, Lex
So after it loads the file is the application available or is it still failing to show? Have you had more than one display connected to the system since initially installing Daz Studio?
Assuming this is the general release rather than the beta you can use http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/specific_ui/screen_size_fhd/start to reset the location - download using the link above the code and double-click to have Daz Studio run the script. For a beta version you would need to use a command line or the new instance script to tell DS to run the script on launch.
Dear Richard, I have reset the PC. I now run only Daz. It runs fine now. I will slowly add my other software and see how it goes. Thanks for the help.
