Modifications have been restarted
For some reason I have opened my project and most of the parameter edits have been restarted. The thumbnail still shows the project with the modifications made.
Is there an option to fix this?
You mean poses, shapes, and/or materials? Check Help>Troubleshooting>View Log File - are theer any errors relating to the scene after you load it, before doing anything else?
I mean shapes make with moprhs. I found the file with errors but I don't see anything extrange, some idea how I can find the error? thanks!
Were these newly created morphs, from dForms or a modelling applications, or settings for pre-existing morphs?
Load your scene, then attach the log to a froum post.
These morph are pre-existing morphs, and I'm using tiem ago, it was now that make this problem. I add the log file.
Not obviously erroring out, and it does seem to ber loading the deltas (shapes) for a number of morphs, which suggests they are applying. Does the figure chnage if you use Edit>Figure>Zero>Zero Figure Shape?
I tried what you said and it didn't work. That way all the morphs are reset, the problem I have is that only a few of them are reset. It's happened again with a new scene and exactly the same. The duf file still shows the original image, but quite a few morphs have been reset. I've seen it also happen when I simulate clothes, but that's reversible by pulling back. I think all this is happening to me since version 4.21, but it's a I think.... I tried restarting daz studio from daz central and it didn't work.
