Stereoscopic 3D VR-360 Renders (For VR headsets)
KomodoVR
I'm planning to create a variety of immersive stereoscopic 3D VR-360 renders and videos, so feel free to check back on this post periodically if that interests you.
Jump to the latest post on this forum thread
(Hopefully, the VR renders have improved over time!)
From my perspective, stereoscopic 3D VR 360 content offers a more encompassing experience compared to VR 180, providing full 3D depth immersion in all directions. However, it's worth noting that creating 3D VR360 renders is more time-consuming. If you find any stereoscopic renders lacking in 3D depth, immersion, or if they appear blurry or doubled as though you're seeing double but are sure you're not intoxicated, then adjusting your VR media player's viewer/playback settings might be necessary.
You can download the VR renders from the provided Dropbox link and transfer them to your VR headset. For this, I use a standard "Quest 2 Link Cable". To view the VR renders, I recommend "Pigasus VR Media Player", an affordable app available on the Oculus/Meta store.
Each VR render file is labeled with the tag "_360_TB", indicating to Pigasus the correct display format for the images on the Meta Quest 2. Specifically, the stereoscopic 3D VR format employed is "360 over/under" (also known as top/bottom). This is important to note if you're using a different VR headset or media player.
All stereoscopic 3D renders I post here should seamlessly work when viewed with Pigasus on a Meta Quest 2. To start off, I've included some VR renders of Victoria 9.
Got a VR headset? Get the stereoscopic 3D VR-360 renders (over/under):
https://www.dropbox.com/sh/e9yg9ahkyq1rhyj/AAAbauxkqSa_qNZrrlRkws6Fa?raw=1
Victoria 9 HD (Stereoscopic 3D VR)
A few more stereoscopic 3D VR renders of Victoria 9.
https://www.dropbox.com/sh/ayq42gx4zsjvgum/AABqKTxGP1oxOvH3Ck5YgMwwa?raw=1
Billboards are not so useful with stereoscopic 3D VR renders
Billboards can effectively conserve GPU resources in standard 2D renders; however, their utility diminishes in stereoscopic 3D VR scenes. Once you view the upcoming render with your VR headset, the limitations of using billboards in this context will become immediately apparent.
https://www.dropbox.com/sh/xk745mjs9n2md9j/AAAocKpqcQFsAqjeD6O5LAB6a?raw=1
The Dark Forest (Stereoscopic 3D VR)
Take a stereoscopic 3D stroll in the Dark Forest environment.
https://www.dropbox.com/sh/hvjds2od5k5mudy/AAAXKhdJOdVdIR3msfOHZl3Qa?raw=1
The Dark Forest With Monsters (Stereoscopic 3D VR)
Watch out for stereoscopic 3D monsters in the Dark Forest environment.
https://www.dropbox.com/sh/mm75ymfc86b3i6v/AAAyV3cfoZ-34bLw3EIAkZcZa?raw=1
World Gardens Japan With Victoria 9 (Stereoscopic 3D VR)
I'm quite impressed by the visual quality of the World Gardens Japan asset in stereoscopic 3D and plan to use this environment in future VR renders. With the recent release of G9, a pose converter would be highly beneficial to broaden the range of poses available for G9, as the current options are somewhat restrictive. The total rendering time using dual RTX 3060s was just over 3 hours.
https://www.dropbox.com/sh/xble8vflbfioqlk/AACGVUBDDUoYMR-J5ShiL_Zga?raw=1
BB3D Environments: Medieval Study (Stereoscopic 3D VR)
Creating an environment for immersive viewing with a VR headset offers a unique perspective on the 3D asset that can't be matched by 2D renders. Over time, I plan to create VR renders of each environment in my asset library. Although I'm not completely satisfied with the appearance of the walls and windows in these renders, additional iterations would likely have improved them. The total rendering time for the three VR renders using dual RTX 3060 GPUs was just over 3 hours.
https://www.dropbox.com/sh/3mdtocp32raz3m6/AACAg6w0ZbFDsR3k1zOGS46_a?raw=1
Archaic Ruins with Victoria 9 and Michael 8.1 (Stereoscopic 3D VR)
The Archaic Ruins asset is quite effective in stereoscopic 3D, and I plan to use it again in future projects. The total rendering time for all four stereoscopic 3D VR renders with dual RTX 3060 GPUs was a mere 42 minutes. This efficiency was due to rendering convergence reaching 100% after only 1040 iterations.
https://www.dropbox.com/sh/hccluita61o3ox1/AABQ5TMhYLXtaEUsXV1FaY-Ca?raw=1
MSO Peppa HD 9 (Stereoscopic 3D VR)
See what Peppa HD 9 looks like in stereoscopic 3D.
https://www.dropbox.com/sh/4sir6k3lvh90pi5/AABYvp4mTdPTgId0GwHlLEFRa?raw=1
Art Studio (Stereoscopic 3D VR)
The art studio environment renders impressively in stereoscopic 3D, and I'll certainly incorporate it in future VR renders.
https://www.dropbox.com/sh/aafjjow8q8rqsbz/AABVpddwlfx0jfxDJcdF9BPAa?raw=1
i13 Laundromat Environment with Poses (Stereoscopic 3D VR)
It's a laundromat in stereoscopic 3D.
https://www.dropbox.com/sh/gagfau8auerehwx/AAB_uUv8bpA4uXS6EdhgQHnWa?raw=1
Komodo I'll definitely check some of these out on my Quest as soon as I get a little free time. Thanks for the tip on what viewer you recommend. I've been wanting to do some renders for VR myself. Do you have any tips to offer for that?
Creating VR renders with Daz Studio is surprisingly straightforward yet inevitably time-intensive. To streamline this process, especially for tasks requiring repetition, I am developing scripts and utilities for full automation.
In time, I plan to compile a guide on manually creating the type of VR renders I've been sharing. Should you try your hand at these, feel free to share your work here. Currently, it seems not many are venturing into this area. While not universally appealing, VR renders can spectacularly highlight Daz assets and renders. My posts thus far have been basic, primarily to illustrate the potential.
i13 Casino Environment (Stereoscopic 3D VR)
It's a casino environment in stereoscopic 3D.
https://www.dropbox.com/sh/cppucgindfuvny0/AADvd8swTSFBdYuDlruCUXgRa?raw=1
Ancient Ruins (Stereoscopic 3D VR)
This appears to be Frankenstein going for an evening jog through some ancient ruins. The ancient ruins environment works well with stereoscopic 3D.
https://www.dropbox.com/sh/5y0xonsddo3tcul/AAAbdvP4dFmLSHQ85OWEBtE8a?raw=1
HD Scans Church Ruin 2 (Stereoscopic 3D VR)
The HD Scans Church Ruin 2 asset looks great in stereoscopic 3D. Other HD scans probably look good in VR as well.
https://www.dropbox.com/sh/m1ljqh9q2kdko6e/AABdL0meEAFsSlkmrPXDTWrua?raw=1
Jin-ju 8.1 vs DAZ Dragon 3 (Stereoscopic 3D VR)
Jin-ju 8.1 and the DAZ Dragon 3 battle it out on Muelsfell's modular badlands in stereoscopic 3D. Who will win? Realistically, the fire-breathing dragon.
https://www.dropbox.com/sh/atm4hn4sfjfhffy/AABj7TUUM_Bph9LSlwRhQyYZa?raw=1
Alien Queen 8 (Stereoscopic 3D VR)
Meet the alien queen in stereoscopic 3D.
Got a VR headset? Get the 3D VR-360 renders (over/under):
https://www.dropbox.com/sh/8df4j6f1778bfmy/AABfKGRrRjmW3oLTU1Dqvf77a?raw=1
The Lost Temple (Stereoscopic 3D VR)
Why risk life and limb hiking to locate the lost temple when the magic of VR can teleport you there?
https://www.dropbox.com/sh/zbjuunikme4qd6h/AAB-Gak9uTMeGBhC3PnyWjwZa?raw=1
Library of Wizardry (Stereoscopic 3D VR)
I like the concept of this asset and will put it to further VR use, but unfortunately it rendered slowly.
https://www.dropbox.com/sh/xfb45r1d63p6l3p/AACrc3_RzwcqnPigm-w9sWvxa?raw=1
Beast's Lair (Stereoscopic 3D VR)
You can only encounter spiders this big in nightmares, gain of function labs, and VR. In VR is best. As usual, Muelsfell's modular environments look great in VR and render quickly.
https://www.dropbox.com/sh/7ot1vewd1u6l1au/AAA3kBYplEbLio38kBkhbPora?raw=1
Alien Archive (Stereoscopic 3D VR)
The alien archive looks great in VR, but it rendered slowly.
https://www.dropbox.com/sh/z26fdyxz7uul8z0/AABoOtIgCh_7uZ-PNw1YX5w7a?raw=1
Gravity Environment (Stereoscopic 3D VR)
The Exile Alien appears somewhat startled and displeased to have encountered you in the Gravity Environment. With a VR headset you can go anywhere that your ridiculously overpriced GPU can render.
https://www.dropbox.com/sh/sdjjj1l7mqmt6c7/AAC-zSCyzFjafG3swT35yUqOa?raw=1
The Underside (Stereoscopic 3D VR)
The underside has a nice gungry cyberpunk feel. Next time, I'll use a night HDRI. Unfortunately, there is a texture defect with one of the stairs.
https://www.dropbox.com/sh/2dq843dnvat4kqp/AAAYXSQASmA7zaSHFJVu0_Wna?raw=1
Muelsfell's Secret Grotto with Nenana HD (Stereoscopic 3D VR)
Nenana admires the view from the secret grotto.
https://www.dropbox.com/sh/sr0dmfrp4ecrzkl/AACipAPm9pSIV1A3EOMIHL27a?raw=1
Michael 9 HD (Stereoscopic 3D VR)
Here are two stereoscopic 3D renders of the recently launched Michael 9 HD.
https://www.dropbox.com/sh/sqxanog6ft6ba9h/AACnOqxkLkhXxK8Rx43vCyLBa?raw=1
Eclipse Sci-fi Environment (Stereoscopic 3D VR)
Stonemason's "Eclipse: Sci-fi Environment" looks great in stereoscopic 3D, though my VR renders do not do it justice. Unfortunately, I did not load the render settings preset that comes with the asset, so the attached image appears very dark. But, it still looks good in VR and I'll revisit the asset soon with proper lighting and some characters to make it more interesting. All up it required about 11 hours to complete two VR renders with dual RTX 3060s.
https://www.dropbox.com/sh/6eiyp0bjjfi3j0e/AAA9A4YcJj1hooti4mm1b8jqa?raw=1
Victoria 9 with Natural Eyes 9 (Stereoscopic 3D VR)
Here are some stereoscopic 3D renders of Victoria 9 with the recently released Natural Eyes 9 merchant resource.
https://www.dropbox.com/sh/0u70d3gmh5v2f6v/AADYMIzdXnYhyueh03ndi6Caa?raw=1
Hexad (Stereoscopic 3D VR)
Some stereoscopic 3D renders of the recently released Hexad environment that is part of the Michael 9 bundles. Hexad rendered quickly and it works well with VR. I look forward to using the environment again with some figures to make it more interesting.
https://www.dropbox.com/sh/l3mlyk9q6tpe853/AAAU9ElRm22QG80lUw-Z3B1ia?raw=1
Ranch Pool Deck (Stereoscopic 3D VR)
Come on in, the stereoscopic 3D water is fine.
https://www.dropbox.com/sh/camy89p74j9qwb8/AADyGEjllLpquDThdCu-PAisa?raw=1
Sunstone Chamber (Stereoscopic 3D VR)
Have you seen the weirdo succubus creature that's lurking in the sunstone chamber?
https://www.dropbox.com/sh/zhwo0xdsk7v8zvj/AADT8o0p-q-L1XUNQ0fCaTo3a?raw=1
