Is There an Explanation of UVs surface UDim set options for Genesis 9?
DiomedeDiomede Posts: 15,396
Greetings.
Is there an explanation of the UV set options for genesis 9?  Is there a way to add more?  If so, how?  Are there existing alternatives in each of the four current categories?  If so, where can they be found?
  • Aside the the base Multi UDIM they are essentially for content creators.
    You can make a new UV set by remapping the base geometry in whatever tool you wish, exporting as OBJ (all without chnaging the vertex or polygon ordering), and then use the Load UV Set command from the Surfaces pane option menu (the lined/hamburger button in the top corner, or right-click the tab). Once you hae and are satisifed with a new set, File>Save As>Support Assets>UV Asset to make it available on all loads of the figure.
  • DiomedeDiomede Posts: 15,396
    Thank you.
