Zombie horse a bit broken
I don't know if anyone else has this problem, but M3D Zombie Horse for Daz Horse 2 is EXTREMELY bugged on my end.
For one, if I have it on a higher render subdivision, it stalls the render entirely.
Second, when loading the horse, it lacks ANY other horse slider but those that come with it.
Does anyone else have this issue?
I'm having a different issue. Ever since I installed the zombie horse, the back left leg on the regular Daz Horse 2 looks off and I can't fix it to look correct.
I figured out the problem I was having with the leg shaping at least. I'm posting the answer here in case others are having it too. But if you scroll down on the horse shaping tab to M3DZH Leg Bag Left Bone 02 for some reason mine was set to 100% as default, so switching it back to 0% resulted in the daz horse shaping being correct again.
I do see what you were saying about lacking the other horse breed parameters. If I load the Daz Horse 2 from the Daz Horse 2 folder, all the shaping modifiers are there including the zombie ones. If I load the horse from the M3DZH folder, I only get the zombie modifiers. I don't render in Daz Studio, so I can't really judge on the rendering time.
Please take notes and pictures and send them to CS.
Already done that. Figured I put this here as a way to let others know of the problem.
Thanks for letting us know, and also for bringing it to the attention of DAZ. Didn't have much time for rendering lately, so hadn't noticed. Hopefully, it will soon be fixed now.
I finally got around to checking this out, and I think what the PA has done with the seven "Actors" are to have some presets ready to go. Yes, they each load with a subset of the zombie morphs and nothing else, probably to keep the load time down overhead low when loading multiple beasts. Can't argue with that thinking. You can get the full complement of zombie morphs when loading a base DAZ Horse 2, but you do get everything else that Horse 2 brings to the table, so you can make a zombie out of whichever breed you want. Zombie Deer? Zombie Donkey? Zombie Llama!
A Zombie Llama..
That really is something you don't see every day...
Regards,
Richard
Today, there was an update on the horsie. Now it remembers all Horse 2 morphs. The subd bug still exists, though.
