Crow 8.1
Hello, I've got Crow 8.1 and here's my questions.
1. Which hair is used in the preview photos? Not the flightful fancy hair that's shown in the primary photo, it doesn't have enough controls to make it "calm down" as it is in the other preview photos, with the shorter hair
2. Why in the world does my crow 8.1 not resemble the preview photos in the least? It's not just the difference in lighting, it's the structure of the face once I've applied it to 100%
thanks for any help
Post edited by akphotography42 on
Hi,
I think the hair is this one:
https://www.daz3d.com/kuo-hair-for-genesis-8-and-81-females
As for the difference between promo and yours, select your figure and check the parameter tab under currently used. See if by any chance there are other characters loaded. Note there are some notorious characters that changes the G8F default figure by loading themselves into the G8F figure upon installation. I can only remember Demona from Renderosity, but I know there are more.
Hope this helps.
Cheers
Currently Used shows only non-default values (I wish there was a way to show all non-zero values). Try Edit>Figure>Zero>Zero Figure Shape, then either manually set the Crow 8.1 property through the Parameters pane or apply the Crow 8.1 Shaping preset (not the Character preset) and see if the result looks correct.
It's Kuo hair. I just bought it and can confirm it. It's decent looking hair, but it has no morphs or articulation that I can find, other than one to move that one stray bang.
Wow, thanks all! Going to get the hair now.
The "currently used" and "zero figure shape" seem to be exactly the threads I needed to pull at.
This model definitely gives Daphne Keen vibes, thinking of working up an X-23/X-force era model
