Iray render problem (mesh getting twisted in the render)
I'm having an issue with attempting a simple Iray render, and I'm at a loss what to look at. For some reason, the Iray render does something to the poster behind his head, rotating it so it disappears into the wall and sticks through the guy's face. I've tried different shaders and adding more lights. Neither fixes it. I'm very new to rendering, so I'm not sure where to even start looking.
The first image is a 3Delight Render. The 2nd is the Iray render.
Post edited by deadlyaccurate on
My first guess would be displacement map on the poster or wall.
Thank you!!
It was the displacement map on the wall that was causing the issue. Thanks so much. That was driving me nuts.
