Problem beim rendern
tankutogatankutoga Posts: 2
Hallo Gemeinde
Ich habe seit kurzem ein problem beim rendern wenn ich rendere wird alles meistens weiss gerendert (siehe Bild) im Logeditor zeigts mir diesen
Fehlermeldung an
3Delight message #45 (Severity 2): S2050: cannot find shader 'brickyard/{407f8e5c-3a9b-4708-b5e5-799ff1fe7c1d}/shader_Displacement', will use 'null'
3Delight message #43 (Severity 0): R2093: object 'shapematerial_Eyelashes_2644_296' (displacement 'DAZ/Uber/displacement/omDispStandard', surface 'DAZ/Uber/surface/omUberSurface') used only 0% of its displacement bound
3Delight message #43 (Severity 0): R2093: object 'shapematerial_Sweater_3796_ec8' (displacement 'dzdisplace', surface 'dzplastic') used only 0% of its displacement bound
Finished Rendering
Ich habe alles mögliche probiert soweit ich drauskomme.
wer kann mir sagen was ich machen muss wäre sehr dankbar :-)
  • StratDragonStratDragon Posts: 3,278
    It looks like 3Delight can't use the shader you picked for the figure
    If your using a custom shader can you try with a standard skin shader instead?
  • tankutogatankutoga Posts: 2
    thx for answaring
    my english is not so good
    its realy in color but wher is the problem :roll:
  • Richard HaseltineRichard Haseltine Posts: 109,366
    Got to your temp folder - you can see where it is in Edit>Preferences.
    In the temp folder, open the Shader folder, then the brickyard folder.
    Delete the contents
    Try rendering again.
    Or save the scene, close down Studio and reboot.
    The start Studio and reload the scene.
    thx Richard
    i have to do that and it's works
    thank you all
    sorry for my bad english
