How to install the 4.21 beta and not overwrite my current DS install
FSMCDesigns
in The Commons
I have a perfectly working version of 4.15 and want to stay with it untill I decide to adopt 4.21 or later. I want to check out G9, so I decided to see about installing the 4.21 beta. Can anyone tell me exactly what file I am looking for in DIM, or what to install manually from my product library to try it out and not affect with my current version of DS.
It should be easy in DIM, the beta is called Daz Studio 4.21 (Os name) Public Build +Beta+ if you search for Public build or Beta in DIM, it should be easy to find.
There are aso Beta versions (which need to be installed if you use them) for varous plug-ins - Photoshop and GoZ Bridges, (Optitex) Dynamic Clothing plug-in, Decimator are the ones that spring to my mind. Again a search fo "public build" should find them all in DIM.
Then you may have other plug-ins you want to use but are not version specific, e.g. Ultrascenery, USC Accelerator and UltraseceneryXT; Mesh Grabber; Thickener; LAMH. DIM normally installs them to both the Base and the Beta releases, but if you have never installed a Beta version of DS before then you may need to reinstall them. (There are doubtless more of these than I listed, my list was just ones that I use most often).
Thanks for the info. I thought I did that exact thing with DIM when I tried to install the 4.15 beta alongside my 4.12 install and it overwrote my 4.12 install, so I was trying to avoid that again.
Thanks so much for that description! For some reason, I can't find the betas anymore in DIM (which I used to get), and now I couldn't figure out how to try out 4.21 with G9 without risking my current working installation. With your help, problem's solved!
So if I rename the DAZStudio4 Public Build folder to something else, can I run DIM to install the 4.21 beta? I would do it manually, but I am worried about content file paths since I use DIM to install content
Thanks Richard. that is what I figured as well. I used to install everything manually, but tried DIM a few years back and have been using it since. I had file install path errors from the saved scenes I had before using DIM and I am trying to avoid that again if I install 4.21 manually.
