CrossDresser4 Conversion Issue
MJ007MJ007 Posts: 1,716
I am having an issue with XD4 when converting Bamboozle from Matt3 to Dennis.
Does anyone know how i can fix this in XD?
-MJ
  • ArtiniArtini Posts: 10,351
    I would like to know that as well.
    Many times when I have coverted clothes with CrossDresser 4, I got the similar problem.
  • ByrdieByrdie Posts: 1,783
    I used to see that happen with some outfits if I had forgotten to check the No Spherical falloff zones box. Here's what it says about in the Help window that pops up when you click the question mark next to that checkbox:
    ** Some converted clothing will "stretch" or "break" when posing the arms and/or legs. This happens because parts of the clothing are outside of the default spherical falloff zones for the base figure. The more baggy the clothing is, the more likely this is to occur.
    By checking this option, CrossDresser will turn off the spherical falloff zones in the converted clothing's arms and legs. This will solve the stretching problem, but may create minor poke-through around some arm and leg joints. This can be easily fixed by using CrossDresser's fix morph functionality. **
    Perhaps that may be of use to you?
  • MJ007MJ007 Posts: 1,716
    Byrdie said:
    I** Some converted clothing will "stretch" or "break" when posing the arms and/or legs. This happens because parts of the clothing are outside of the default spherical falloff zones for the base figure. The more baggy the clothing is, the more likely this is to occur.
    This occured while having that very box checked. I couldnt figure it out, so I gave up on it and went with a another outfit that works perfectly.
    So thanks anyway!
    -MJ
    Also had that happen, no idea why. Sometimes I was able to fix it by converting again with the box unchecked, sometimes it made no difference what I did. Or whether I was using XD3 or XD4. Guess they still got a few bugs that need stomping in that program, then again it just might be that particular outfit. Sorry it didn't work out but good to know your other choice worked so at least he won't have to go around in his skivvies. Er, unless he wants to, that is. ;-)
  • KeryaKerya Posts: 10,943
    Thanks. I have breakage in the Vicky fantasy robe when I converted it -- outer robe not the MFD -- and I'm hoping this will fix it.
