Iray image series rendering not wait "apply mesh smoothing"
This problem has existed for a long time,some people want to solve this problem through scripts, but there is no follow-up. Should I feed it back as a bug? or someone can tell me where to find such scripts,thanks.
Octane render does not have this problem. I can't believe that the development team has kept this problem for nearly 7 years.
I can't remember which is the proper sense, but you can try setting interactive mode on or off for the modifiers.
I've never witnessed that smoothing issue at render time nor during Iray previews ? Weird.
But TheMysteryIsThePoint is absolutely right. Set : Parameters Tab > Your_Cloth > General > Mesh Smoothing > Interactive Update to : On (before rendering)
And it should fix the issue ?
I've run into this a few times. I think I recently finally figured out what was going on in my case, at least: It seems the smoothing modifier is based on the viewport "SubDivision Level", not the "Render SubD Level". Presumably this is because smoothing is not run again after the figures are further subdivided at render-time.
In most cases this doesn't result in poke-through, because more subdivisions often just smooths everything out. But if the underlying figure has HD morphs applied, which can have very different shapes at SubD 1 or 2 vs. SubD 3 or 4 or 5, it could change how the clothing interacts with the figure when the subdivision is increased for the render.
Think of having a vein morph that pops the skin out a few millimeters at SubD 4, but doesn't really do anything at SubD 1. If the viewport is at SubD 1, and the clothing is very tight to the skin, the smoothing modifier isn't going to get a chance to shape the clothing around the veins.
Unfortunately, the only way I was able to fix it when this happened was to increase the viewport SubDivision Level of the underlying figure to the Render SubD Level and let the smoothing modifier do its thing just before rendering. (edit: make sure you unlink the Render SubD Level before increasing SubDivision Level so it doesn't also keep increasing, they have to be the same for this solution to work.)
The other possibility could be that the clothing has different viewport and render SubD levels, and for some reason it's pulling tighter into the skin with higher SubD levels at render-time without another opportunity to be smoothed. The solution would be the same, increase the viewport SubD of the clothing to the render SubD. That's probably a better approach to try first if there is a difference between viewport and render SubD on the nylons, since doing it on the figure can make everything painfully slow depending on your computer.
This method is only suitable for single frame rendering and cannot solve the problem of image series rendering
sadly no,I tried all the methods I searched
