G8 to G9 batch Pose Converter
in Freebies
I made a small GUI application to convert entire pose Directories from G8 to G9. The conversion is not perfect put is works well enough
Prequsities:
- install Python3.6+
- install pyside6 ("pip install pyside6" in terminal )
- extract zip
Usage:
- Double click G8toG9PoseConverter.py
- check recursive if you want to convert poses in nested folders
- select source folder
- select target folder
- click start
I recommend that you set the target directory outside your Runtime. And copy the converted files poses manually.
Please tell me if you have any Problems.
Where do you get these items?
Second...
I know about Python https://www.python.org/ftp/python/3.10.8/python-3.10.8-amd64.exe
no good on Win7 through
I found this one: Hope this helps :-)
https://www.python.org/downloads/
https://pypi.org/project/PySide6/
