Jpegs as backgrounds
I have been using HDRIs but also obtained various backgrounds that are large jpg photos. I have a problem figuring out how to use the jpgs as backgrounds. I will create a plane and then set the jpg to the Base Color attribute on the Surfaces tab. I then just scale the plane and it appears fine until I go to render. When rendering, I get all sorts of weird artifacts on the jpg. In the past, I have noticed that they were shadows of other objects in the scene appearing on the plane, but the sources of them can be a real problem tracking down and correcting. Is there some attribute of the plane that I can set that will eliminate these artifacts appearing on the jpg plane? Or maybe there is a completely different way to handle this, in which case, if someone could let me know, I would appreciate it. I like the idea of using JPGs rather than HDRIs when possible as they can provide a lot more options in my compositions due to their wider prevalence.
How about
go to the render tab, environment, set background, select your image, and render?
You can use your image as a Background in the Environment Tab
There is no "set background" option under Render tab | Environment. I am using DS 4.21.
Where on the Environment tab is there an option to specify a background jpg? I know how to set a HDMI image, but not jpg. If I try to use a jpg in place of HDMI, it comes out distorted.
How do I put it in the emission channel? You mean setting the jpg as the Emission Color attribute? That doesn't work, so I don't understand which setting you are referring to. Also, it isn't clear why reflections being turned off would matter since it is the shadows of other objects in the scene that cause the artifacts that I have come across, not reflections of anything that I know of. Can you explain what you are getting at?
The place for the .jpg is in the menu Windows/Pains(Tabs)/Environment, Type is Backdrop in the drop down. Click on the arrow under Background and find the image you want to use.
See video:
https://www.screencast.com/t/QM14iEROHNF
Yes, that is where it is. Thanks.
Got it. Thanks.
Ah, you want to load the image both as the base color and emission color and set the glossy color to black so it is matte since backgrounds shouldn't shine. I used a photo with Bokah here:
Yes - this is exactly how I do it too.
