Do up look forward to new generations or do you dread them?
2»
  • takezo_3001takezo_3001 Posts: 2,026
    edited October 2022
    Mada said:
    I am looking forward to the M9 release yes :)
    Please note - if G9 loads with flexions and joint correctives off there is something wrong with your G9 install. The figure should load with it activated. If you use Zero Figure it will reset the correctives to zero. Use Restore Figure instead, and I use Zero Pose or Zero Morphs as well.
    Thanks for this info, I'm re-installing my G9 and morphs as we speak!
    EDIT: Well, re-installed everything, yet when I load my G9 the flexions are still disabled, yet has the default value as evidenced by the equalised text colour of the value input; the joint correctives are turned on so that's something…
    Post edited by takezo_3001 on
  • nonesuch00nonesuch00 Posts: 18,753
    No, I continue to use what I like and like the improvements in new tech. I do few realistic renders and only to see technical progress. So no new generations would mean no new purchases for me, which has been the case increasingly for Genesis 8 / 8.1 until Genesis 9 changed that. Now I'm no likely to purchase as much for Genesis 9 as I did for Genesis 8/8.1 but I might with the right sort of releases.
