What are the purposes of different UV Sets for Genesis 9?
amy_aimei
I noticed there are 5 UV Sets for Genesis 9. They are:
- Base Multi UDIM OLD
- Base Multi UDIM
- Base Single UDIM OLD
- Base Single UDIM
- Genital Map Bake
The default is Base Multi UDIM. What are the purposes of the other UV Sets? How to use them?
Single UDIMs consolidate all the skins onto a single map, which makes it simpler to work with some painting tools - one of the Genesis 9 utilities will split such combined maps into the standard maps.
There was a change, fairly late, to the UV layout so both are still there to allow PAs to conveniently swtich their maps to the new mapping.
I'm not sure about the last, but I would imagine it is used in ensuring that the genitals merge cleanly with the base textures.
In practice the default Multi UDIM will be the one you need.
