G9/V9 & G8 Strand-Based Hair Save/Load Issue?
nakamuram002nakamuram002 Posts: 810
FYI:
I have reported a suspected compatibility issue with G8 dForce Strand-Based Hair and G9/V9, to DAZ tech support.  They are investigating.
I can load and conform a G8 dForce Strand-Based Hair on G9/V9, run a sim on it and everything is OK.  I can save my result as a scene or sub-scene.  However, when I load my new scene into DS, the hair is messed up and cannot be re-conformed nor corrected in any way.  I have tried two hairs with the same result - PhilW's "Suzina Hair" and ChevyBabe's "Soft Curls Hair".  See attached images.
Has anyone else experienced this problem?
Post edited by nakamuram002 on
  • I believe that this is a DAZ Studio "save/load scene" issue that needs to be fixed.  The "Suzina" and "Soft Curls" hairs autofit, conform, and simulate properly when used on G9/V9.
  • DAZ says that this is a problem with compatibily that will not be addressed.  I have requested a refund on V9.
  • Well that's not going to solve any problem. You know one can make their own Strand-Based hair in D/S. And V9 has some lovely hair made for her :-)
    Thanks Catherine3678ab.  The problem that is solved is that I really do not have to spend any more $$$ - I have plenty of good G8F clothing, dynamic hair, and shoes.  Temptation to buy has been eliminated!!  Plus, I prefer the way G8F bends when the DAZ Body morphs are used.  To me, G9/V9 bends like V4 and earlier figures (kinked tubing), when DAZ's body morphs are applied.
    I do not have the skill to make strand-base hair and there are a lot of nice hairs for G8.  I do not like any of the present G9/V9 hairs as they are all "non-dynamic".
  • Yes there is a lot of content for G8F and certainly no reason to give up on that model.  I like the expressions for V9 and figure that for close-ups, portrait work, she has the detailing I like, esp. the eyes.
    If closeup portrait work is what you do, then G9/V9 is the model for you.  She certainly has a lot of expression flexibility and there is a lot to play with.  I am the opposite - I do full body, zoomed out renders, so face detail is less important to me.  I am pretty certain that I will be using some form of G9 after all the kinks are worked out and appealing clothes, shoes, and dynamic hair become available, but until then...
