One ringy dingy... [Commercial]
Valandar
http://www.daz3d.com/fantasy-rings-for-genesis-2-female-s
Do they represent true love, or the birthright of a haughty noblewoman? Do they grant mystic power, or merely show the wealth of their wearers?
Rings of Gold, Silver, Steel and Bronze; all adorning the fingers of your Genesis 2 Female(s)!
Whether merely one simple band, perhaps with an inset gem, or a different ring on every finger, these eight rings will add grace and attitude to the hands of their bearers!
Each Ring preset loads rings onto all of the fingers so you can use them with ease! Visibility presets are included to Hide/Show all of the rings at once or each ring individually so you can mix and match as much or as little as you want!
About two days ago, i actually said to a friend "There are no good chunky cool rings for Gen2F"......
Damn, you're good! :) :)
Definite purchase! Great uses for good and bad fantasy characters, alike. Maybe sci-fi, too.
Are you going to re-do your 'Armor Rings' set for Genesis 2? Would love to be able to create a taloned gauntlet with those on all fingers/thumbs for my vampiric characters in HD.
Not sure if I am or not. If I do, it'll be done similar to this set - any given 'ring' will have one on each finger, with hide/show poses for the fingers you want.
Played with these in Iray - The bottom ring has no adjustments to the surfaces at all....the top ring I added the Iray glass shader to the Cornea and messed with a metal shader a bit. Love them both. They work great. :) The non adjusted ring could use the glass shader so it converges the surface in the render a bit better, but overall they are looking good out of the box. :)
Kat
Ooo...Those look great. Good for Gen 2 and I know I'd wear them if they were in the real world.
