how can I make the ropes moving? on boxing stage?
foxyfoxfurries
Hey! I have few boxing arenas but lets say I use this one : FG Tough Boxing Gym | Daz 3D
How can I make the rope moving if the character lay on it or touch it? I have more arenas if that one can move , Thanks :)
First thing to check is whether the ropes are split into several polygons along their length - switch to a wrire Drawstyle, using the sphere icon next to the camera/view picker button at top-right of the Viewport and look to see if the are lines runnign around the ropes at intervals. If the rope isn't split into segments (and the product you list looks pretty straight so it may not be) then the only way to do it would be by modelling new ropes (or possibly just replacing them with cylinder primitives with divisions along the length). If you do have, or create, ropes with divisions then you could just use a dFormer.
The rropes are not cut in to segments so they cannot be made to flex.
Ahhh that's a shame : / All my boxing arena dont have what you saying , It means I need to replace them like you said or just cant make them move , about D-Former I give it a try , wish was boxing arena that have to make the rop flexible easy hehe
Well, there are some out there. Have you heard of the Pandorian wrestling ring?
Ummm no but its on shop and it looks like boxing ring? xD
Hey! We actually discussed this a while ago, if you recall. About Boxing Stages Ropes. I see that it might have been a bit technical for a beginner, but maybe now you are ready to try it? The sticky point is having ropes with enought mesh density.
Heyyy yes I remember it was so hard to do! I may give it a try again haha but again shame that no have Boxing Ring with this option hehe it was easy to people like me :)
Hey only wanted to say thank you very much I did what you say I know its still not that perfect but I will train on this more , wish was ring with ready ropes but this also can work! Thank you! :)
BTW where can I find the D-FORMER SPLINE EDITOR? To change the shapes
On the D-Form tab pane, there are a number of buttons, one of which is "Edit Spline...". It will open a graph of the current curve, which you can modify by dragging the control points. In my example, I had made it a straight line, so that the ropes stay straight when using the D-Former.
Hey thanks again , but when you said Edit Spline I cant find it
The DForm tab, not the Parameters Tab. You might need to open it from the menu (Window-> Panes (Tabs)->DForm)
Thank you very much!!! :)
