Adding to Cart…
i refreshed my UTAU skills, because i want a singer for the voice track
it's not very good, but more interesting than a midi-reed organ
http://mcasual.x10.mx/charona.avi
what is UTAU ?
UTAU
Might be this
A shareware vocal synthesizer program unlike VOCALOID, VOCALOID2, and VOCALOID3, which are commercially-sold programs with an accompanying voice bank
what is UTAU ?
you have banks of .wav recordings of vowels and consonants,
for example you record the sound 'A'
UTAU can detect which note this sounds like
UTAU can shift the pitch of that note to make you sing 'A' in any note of any octave
you lay out your notes and your vowels/consonants on a staff
and that's it, you get synthesized singing
example (not by me ) https://www.youtube.com/watch?v=nWodEKXX7Mw
note that most voice banks out there have licenses like "attribution share-alike non-commercial" and other restrictions
The release/manual page will be located here: https://sites.google.com/site/mcasualsdazscripts5/mcjmidikit
tomorrow probably, i'll at least post the MidiLoader
it creates a midi node with up to 16 channel nodes, each channel node contains the notes on-off events as labeled properties
i'll probably also post a script which lets you do some animation using it
the real script to build more complex animations will come later
the third upcoming script is a sort of specialized pose-animation saver
for example to store the animation for Amy's Right arm bringing down a drum stick on the snare
it was almost ready, then i tested the Pink Floyd/Syd Barett song "Bike"
and realised i need to support variable tempo and even variable signatures !
see this midi track ... just for that purpose
"Well spotted "
Tempo as for music. The speed at which music is or ought to be played, often indicated on written compositions by a descriptive or metronomic direction to the performer.
For example, a tempo of 60 beats per minute signifies one beat per second, while a tempo of 120 beats per minute is twice as rapid, signifying one beat every 0.5 seconds.
Time signature
The number in the top of the time signature tells a player how many of a certain kind of note there are in each measure. The number in the bottom of the time signature tells what kind of note is used a certain number of times in each measure. The number on the bottom of the time signature can be any number that follows the pattern 1, 2, 4, 8, 16, 32..., where each number in the pattern is two times the number that came before it. So, 64 could be a number that is put in the bottom of the time signature, but 65 could not be one.[1]
Number on the bottom of the time signature What it means
1 A whole note lasts one beat
2 A half note lasts one beat
4 A quarter note lasts one beat
8 An eighth note lasts one beat
16 A sixteenth note lasts one beat
http://www.daz3d.com/forums/viewreply/36865/
Added to the index, but I don't think the description is terribly helpful - can you suggest a (brief) alternative?
maybe
"MIDI Animator"
Hi I created a test MIDi and a WAV file from my Keyboard
Added this to the Pose dir in Poser 10
Then after rendering the Video using the MP4 option in Poser
I must admit I haven't seen the MP4 option appear in Daz Studio?
Using Magix Movie Edit Pro , I aligned the Video with the WAVE file
Not to bad a result for a start
click here if you would like to see
http://youtu.be/Xs_qKy_F9BA
I'm really looking forward to seeing your work, so we can Animate things as well using Daz
Kind wishes
Keiron
Thanks, I updated to use that.
yes looking good
Daz Studio only exports in avi
though the avis can use compressors like DivX which is mpeg4
it's often better to save your scene before using special compressors, they tend to crash the program
safest is no-compression but the avi files are huge
i often render uncompressed or as jpeg sequences then use VirtualDub to to the DivX compression
plus it's easy to crop, resize and add overlays in virtualdub
thanks for doing this !
someday i may make a nice list of links and short descriptions,
so you could add the missing ones without too much work!
Misstick playing the first 4 notes of "Bike"
the piano keys were pressed by a program
but the hands had to be manually posed
the script will also let notes create lasers
and well anything, including balls bouncing off xylophones.
i 've worked on making the script able to cope with tempo changes
because it complicates the conversion between midi timestamps and "real" time
still got to fully understand the global midi "divisor" and the time signatures
New 30 second video showing excellent synchronization of a keyboard with midi music
https://www.youtube.com/watch?v=N_NIBHZLUGc
Very well done
Keep up the great work.
Just an idea
In the MIDI data some notes are in the same time stamp
block or very close
if you can somehow recognise when all the notes play at the same time, there's a good bet it's a chord
for example c
left hand c-e-g-c or c-e-g or e-g-c or g-c-e or c-eflat-g ect
right hand simular but higher up the scale
That may then allow you to position the hand to the correct Octive, maybe locking it to a specific note or set of notes
there's a script of mine, mcjAutolimb, that will help animate the arms
you select a null node, select a hand or a finger and the script makes all the arm pose'ing needed
to bring the hand or finger at the null node location
since i want to get back to completing other ongoing projects
i'll only write a standalone tool for rough wrist positioning
in the case of Pink Floyd/Syd's Bike piece, the left hand was 1 note, and that note was always on the same midi track
the right hand was on the 3 other tracks, so i could have a script position 2 null nodes at the average note positions
the user will select the tracks for each hand.
one could even write a silent midi track for the wrists and use that for wrist positioning
here's the solution i came up with
the keyboard must contain 2 null nodes indicating the beginning and end of the keyboard
first i gather all the midi Note-on / Note-Off events
i sort them by time
i group them by timestamp
then for each group of notes at each timestamp
i assign the notes (keys) to a hand
according to their distance from the current wrist positions
for each hand i compute the average note
the new wrist position is moved to that average note position
note that inevitably some limit cases will lead to nonsensical situations( notably when hands cross )
but most of the wrist positions should be a-ok
Auto-wrist-positioning tool
Video demo!
https://www.youtube.com/watch?v=P29kp7sluzI
The midi-to Daz Studio kit of scripts
will include a script which attempts to assign keys being played to each hand
and mark the position where the wrists should be positioned.
Then using a script like mcjAutoLimb, you can make a figure's hand follow those markers.
So it's not a fully automated solution, but i believe it can save many hours of work for music-video projects
you'll notice that there's collisions between hands at time and other times
when the right hand mistakenly takes the responsibility for a key that was intended for the left hand
So there will always be a certain amount of corrections to be done by a human
i discovered that mcjAutolimb when run on a 3000+ frames animation
will eat up very large amounts of memory ( at least on DS3 )
2 or 3 GB, same goes about mcjKeepOrient ---
that's mainly because the "Undo" mechanisms store
a trace of the millions of operations that
happened when using those scripts
since both these scripts were needed to do the arms animation
i'll probably post very soon versions with no "Undo"
Hi Casual
Well impressed, very cool
Great Keyboard hand positioning
Finger positioning could be very individual to each player. You could use Power Pose or an Animate block
for the last finger detail
Good point about the memory load, I moved to Windows 64 Bit operating System and use the Daz Studio 64 bit version
I've installed 24 Gig of Memory. I know Daz Studio can only render to 4 Gig Video with the 64 bit version, that's why I export single frames and rebuild it, However I' m not sure If Daz Studio will use all the available Memory for normal actions. I hope so
Just a thought reguarding the hand collisions, it would be quite normal for hands to cross over or under each other, so if the MIDI Data was clear for say the left hand, maybe it could be slightly lifted and moved to allow the right hand to pass under or maybe use some form of hand colision detection to take an action
Thank you for all your Hard Work
Kind wishes
Keiron
workin on the midi project today!
featuring the new Wurzkeil keyboard
the music sheet stand will be added to the Wurzkeil prop soon
Amy, Misstick and Toobina in the practice space ( and Gene?, explore the space! )
example of a profile for the mcjWurzkeil keyboard prop
this file format should be adaptable to other keyboards
for example, keyboards with vertically moving keys
if the given keyboard uses morphs instead of rotations/translations
then the control type "morph" can be used
if the keyboard is a color organ, then the control type "color" can be used
or the control type "strength" to animate the ambient strength of a color organ light for example
the keyboard animator ( or anything vaguely like a keyboard )
will include materials animationability :)
the profile for this keyboard
( didnt you see it's a new free prop !! )
and ambient strength animation
is a text file like this
a typical line
means
if midi note 24 ( note = C of the second octave ) is played
search for the keyboard named "mcjWurzkeil"
and in mcjWurzkeil, find something named "notes"
and in notes, find something named "note00"
look in the materials of note00
take the first material ( it could be a material name instead of number 0 )
find the property named "Ambient strength"
if the note is off, set ambient strength to 0
if the note is on, set ambient strength to 1 (100%)
with Daz Studio 3 the daz scenes were properly saving material animations
with Daz Studio 4 you'll have to use a special script of mine to save/load them
Hi Casual
Great looking Keyboard
It would be cool if it could work on different Keyboards like an 88 Key Piano, Grand of Course LOL
Perhaps a quick scan of the MIDI file would let you know what Octaves have been used
full 88 keys, 61, etc
Looking forward to tying out your program in the near future
Great Job
Best Wishes
Keiron
i introduced the "profile file" to let you adapt the player script
to any keyboard that has individually animatable keys
you only need a text editor like notepad ( i used Excel actually )
to create that profile file for an up to 128 keys keyboard
each key needs a line of the form
note that '35' is the midi note number
my mcjWurzkeil keyboard keys are depressed by rotating them 7 degrees around the x axis
if the keyboard keys were depressed by moving them 1.5cm down the Y axis
if the keyboard is a laser harp or a color organ the kine for each key looks like
the profile file lines would look like
i almost forgot
new demonstration video showing midi-material animation
and the mcjWurzkeil in action
https://www.youtube.com/watch?v=lvixbCmzE2Q
fig 1. - puzzling situation
Amy will replace Misstick on the keyboard because her hands are more standard and can do octave-wide chords
i worked some more on automating wrist placement
one issue to solve is to avoid unnecessary wrist movements
i'm getting good results, but only because i supplied the script with some preferred wrist positions for groups of notes
i want that script to be applicable to any musical piece, albeit with results that will necessitate cleanup work on the animator's part
i don't plan on working on that ( master's-thesis-worthy-topic ) for much longer, so it wont be a turn-key solution
see here
System for Automatic 3D Animation of Piano Performances, June 2010 – July 2012
Role: Lead research assistant, directed by Professor Bernd Hamann and Michael Neff.
http://graphics.cs.ucdavis.edu/~zhuy/Project1.html
there will be a small Utility script named mcjHands to help the creation of ( usually bird-eye-view ) hand poses
sorry casual as I do not know where else I could ask you this
matanim works fine but the animation in the surface tab is not save able in a studio 4.7 szene
any help ?
Hi Casual
Looking cool, great job
I was using the Genesis Gorilla in one of my renders for fun, but the thumbs were to short LOL" however you could possible cheat and grow the finger" The legs were also a problem as they were to short to touch the pedels, the way I got around that was to reduce the height the Keyboard and Chair
Placing the Thumb and Pinki right on the edge of the front of a key, may assist in getting a really wide hand profile. With practice you could get over an Octave spacing
Kind wishes
Keiron
