[Solved] My default opening layout has gone bonkers!
nwleee_a52bfead84nwleee_a52bfead84 Posts: 108
edited October 2022 in Daz Studio Discussion
I don't know if it's something I did, or something about the latest release.   But every time I open Daz Studio, the Viewport always opens in FULL SCREEN Mode and the background is white.
Normally the viewport would open within one pane, so you could see the rest of the sections and tabs, with a dark grey background.  (see image below)
So each time I open Daz Studio I have to go to the top right drop down menu, and unselect Full Screen Mode.  But then the viewport is not docked, it's free floating over to the right side of the screen, and still white.
So then I have to go to Window-> Workspace -> Select Layout -> and select my layout.   I even saved this layout as "Default Advanced".
I'm using the latest Daz Studio 4.21.  Attached image is the way I have always had my setup (across two monitors).
The other image is currently how Daz Studio opens with the white full screen layout.
Post edited by nwleee_a52bfead84 on
  • It is important to close D/S [and be sure that none of the components are still running] before installing D/S updates.
    You can try closing the viewport window. Then going to Window/Tabs ... open it again.
    Dock it to the center top.
    Or you can close it and again go to Window ... change the layout or workspace to something else, then switch it back to your preferred layout or workspace.
    Or you can close D/S, uninstall it and be sure it is all finished stopping. Then reinstall it. Uninstalls should be done via whichever method was used to install it in the first place.
    Thanks, I'll give thsoe things a try!
    I tried your suggestions but Daz Studio will still open with the same full screen viewport, and a white background.   It seems to me that there was an option to open Daz Studio with the previous layout. But I can't seem to find that in the preferences.   I feel like I'm missing an obvious solution.   It's not that big of a deal, just a little hassle going through the steps of Exiting full screen mode, and selecting the layout that I want, each time I start the software.
  • It could be that there's a certain file that needs to be 'remade' -- Richard H. knows where that might be. I don't.
    Under Preferences > Interface, at the bottom, there is a "Restore Factory Defaults" That might help get it back.
  • nwleee_a52bfead84nwleee_a52bfead84 Posts: 108
    edited October 2022
    Thanks for your response.   But actually, it just started working correctly again last night.   I don't know what I did (because I tried a bunch of things), but now Daz Studio will open correctly with the layout I want, and no more "full screen" viewport either!
    So, I'm a happy camper now. laugh
  • kenmokenmo Posts: 1,108
    I too frequently have this issue and find it very frustrating. Is there anyway the various planes can be locked in their postion so that they can not be moved or closed?
    Sometimes I will be dragging my mouse  and it will cause the plane to close or bemoved somewhere else?
    Love DAZ3D but I truly hate the fat the UI is so customizable. I much prefer an UI that is etched in stone, kind of like Blender.
    It also makes following tutorials easier.
    Cheers
    Kenmo
    Cheers
    Kenmo
    If you're referring to the Panes, such as Parameters or Surfaces, Window>Workspace>Lock Docking/Undocking, or CTRL+U is the default shortcut.  This will lock panes and groups so you can't click and drag, and you won't have the option ot close tabs.
    If you're not aware of it, you can save your custom layout, Window>Save Layout As..., or F4 is the default shortcut.
    Wow,,,many thanks, Was not aware of this. Many thanks...
