Need help with making custom morphs using 3d-scan models
Hello everyone! I'm using 3d-scan models and Wrap 4D to make some realistic poses and morphs, basically everything works pretty well. but when I do adjust rig to shape, my morph is broken. please help me to find out which of the following steps I did wrong or what else I may forgot
1: I load the 3d scan obj into daz studio, pose g8f according to the scan's posture.(for more accurately posing, I set all nodes limits off and use some morphs to change the bone scale such as shoulder width or limb length...)save the rusult as a pose and shaping preset, then export g8f as obj
2: import g8f obj and the 3d scan obj into wrap 4d, try my best to wrap g8f onto the scan, save the geometry(obj) after it's done.
3: load default g8f in daz studio, select all nodes and turn limits off, apply the pose and shaping preset, then load the wraped geometry as morph using morph loader pro( set overwrite existing: deltas only,reverse deformations:yes).
4: apply the morph to g8f and it looks amazing, other head morphs and expression dials also work properly. the only problem is the rigging has not been adjusted to fit the shape, but if I do adjust rig to shape. it will distort my shape to fit the rig, instead of adjust rig to fit the shape.
ps: in step 1, if I didn't pose the figure before export it to wrap, then in step 3, I will not apply pose but directly load the morph and apply it. after adjust rig to shape, seems like this time the rigging are perfactly fitting the shape but the bone nodes have no transforms or rotation informations, so if I make a key animation from default T pose to my morph's pose, the figure's limb will be distorted during animation. wardrobe or accessories and facial expressions are broken even more.
I also tried to load 2 figure, one with pose applied before load the morph(as step 1-3, rigging incorrectly), another without pose but only load the morph(rigging correctly), then use transfor rigging try to transfor one to another, but that ended up with a totall mess.
I took some screen shots, please check them out. any help will be greatly appreciated!
I posted the screenshots below if anyone can't open the attachements
