Adding to Cart…
I want to see what MarcCCTx gets.
No, it doesn't look fine. The 5-6 versions do, but the female 9-10 version does not! The female 9-10 version still has too big breasts. Your pics clearly show that. No 9-10 year old girl has such a breast shape. At that age there still shouldn't be any difference to the masculine breast shape.
Edit: But maybe you just need to increase the chest flatten morph for the 9-10 girl in that case. 62% seems insufficient here.
You're suppose to blend them in..Both at full strength will never look right.
this is 5-6
And you downloaded the update correct?
ok, but even with only g9 base + v9 + Age 5 comes the breasts :)
Thats because you are blending in V9's body morph which has breasts on it. Dial down v9's body shape. Growing Up is and has always been about blending morphs together at the right values. You will not get great results if everything is dialed in at full.
ups ok found my Error
Argh, I must have installed it wrong the first time, I reinstalled the update. And now* it works. I'm sorry to have wasted your time.
Yup, you're right, 62 is too low ...
Here is 100 and 150%
150% looks close to correctness. So I guess you need to set the flat chest morph somewhere between 150% and 180% for the 9-10 girl.
Awesome glad it's working.
Not your fault. It's usually standard practice when a new figure is released to also release the head and body morphs ON THE SAME DAY. This iteration of Daz must have missed the memo.
I just loaded this with DIM, and then copied the patch files. The Base Morph works, and the presets, and zero utilies work, and the new Flatten morph works. None of the other sliders seem to do anything, or even want to move. No errors reported.
Tested on a fresh base V9 and base G9 with male character applied.
Also, GU for G9 does not show up in Smart Content/Shaping, unlike GU for previous generations.
Yeah, it's really irritating that they are holding back/neglecting to release it until some unknown reason which makes no sense to us! Thanks for the fix, it really sucks that DAZ neglected releasing the morphs on the same day as the character/s which really put a damper on your product release that should have gone off without a hitch!
Hats off to Zev0 for making a GU for G9 so quickly :)
Thank you for the quick update job. Update promos is essential for your business, not for those who have already bought your product.
Then it was just a bug, I guess. Not that it was not hilarious AF XD
Can confirm, excessive hormone treatments removed. Thanks Zev! :-)
Those for whom the fix is not working, how did you install the base product? Did you get warnings/queries about replacing files?
Thank You for supporting us with making sure each release is a successful one, including this one, as you've shown your support for those that buy from you, regardless of the issue, as we are confident that you will always do everything in your power to make things right when things go south!
The sign of a good content creator.
Wow, fixed already! Into my cart it goes.
Zev0 is a first class vendor, others could take a lesson on the great customer support.
