DAZ Studio Pro BETA [Project Iradium] - version 4.8.0.4!
1101113151645
  • DAZ_SpookyDAZ_Spooky Posts: 3,100
    MacSavers said:
    MacSavers said:
    Second Question: How do I control which view to use for the Aux Viewport? I'd like it to use a camera instead, but it seems to be staying on Perspective View even though I have the main camera view selected in my Viewport.
    You should have the same controls, including camera picker, in the Aux Viewport as in the main.
    If I let it render once, the menu goes away and I can't seem to re-click it.If you stop the render the controls should come back.
  • R25SR25S Posts: 595
    Another Problem; this time I need some advise for the Render Settings of NVIDIA Iray.
    When I render DAZ Big Cat 2 with NVIDIA Iray the complete Mouth (Teeth, Tongue and so on) render completly blank. In 3Delight they render fine.
    900 x 692 - 178K
    900 x 692 - 233K
  • MacSaversMacSavers Posts: 324
    Okay, I'm able to push the boundaries a little further. I pulled up a Dynamic Clothing test I did when I was trying to get my mind around how it worked. The dress is frozen, so it's not technically dynamic any more, but it was a good test for time.
    4.7 : It took the first render 2:38 minutes to finish, but it also required a pre-processing of 72 images. Subsequent renders only took 1:18 minutes.
    4.8 : It took 3:16 minutes to render from the main viewport. It didn't to any pre-processing because the Aux Viewport did it prior to doing the render. What's odd is that it only pre-processed 50 images, not 72.
    So, the Iray took 2 minutes longer. Now, my nVidia is only a 650m and only has 512mb of ram. Also, the Aux Viewport was able to render the scene much faster, but it was also like 1/8th the size.
    There are also anomalies with the render. I have a plane with a cube under it. Since the plane won't interact with the Dynamic Gown, I place a cube 0.001" under it. 4.7 had no issues with this, but the plane stops rendering once it reaches the cube.
    1441 x 720 - 195K
    cwichura said:
    Vaskania said:
    what IS the preferred lighting for Iray? UberEnv? Spotlights? Special sets?
    You should have 2 new lights on your upper bar, photo real point and something else.l
    Points and spots should not be used in a PBR; they are very unphysical and result in extremely hard shadows. When using PBRs, you should always use area/mesh lights for the most realistic results (when not using image based lighting or a sun/sky model). I've not messed with the iRay beta, but from what others have said, there is a shader included to turn a surface into an emitter (e.g., an area light). That is what you should use to light everything in a PBR. Either apply it to surfaces already in the scene (e.g., many Sci-Fi prop sets have surfaces in them intended to be emissive) or create a plane primitive and apply the emission shader to the plane. Then size and place the plane like you would a softbox in real life photography.
    Does IRay support surfaces with both a base material and emission at the same time? This is needed to prevent lightsources in the camera frame from being transparent. (Sometimes transparent is good, like for a lightsaber, other times not so much.)Not entirely true. We did include Photometric Point lights and Spot lights with this beta, specifically for use in Iray.
    Light sources in the camera frame being transparent? Aside from the Photometric lights, not in Iray.
    It appears to be too much light washing things out here. Please select the Camera, and in the parameter's pane turn off hte "Headlamp" and see if that works for you.
    Vaskania said:
    What are the Photometric Spot and Point lights for?
    Just like Point lights and Spot Lights in other render engines (To include 3Delight) though these accept real world values and allow you to change the size and shape of the lights. Also the Point light allows you to apply an IES profile.
    There are no lights used in this Scene.
    This Scene has only the Big Cat 2 inside.
  • KatherineKatherine Posts: 330
    Is the Ground plane for Iray turned off? Render Settings > Environment >Ground > off..
    See if that helps.....
    Kat
    That's what I thought. Thanks.
  • RCTSpankyRCTSpanky Posts: 850
    I have try to install 4.8 and I get an error, because some directories (that I never had before in my current 4.7 installation) like "Applications" are missing. Now the installtion always failed and I can't do anything. Unfortunetely I can reconize the errors, because the nstallation fails now, but don't show the error page again. Any ideas.
    This Scene has only the Big Cat 2 inside.There are two light sources in that scene.
    You have sun/sky providing light. You also have the Headlamp (Think of it as a Camera mount flash). If you had no light, your render would be black. :)
    1000 x 1300 - 496K
    1921 x 1117 - 532K
    If there are no lights, the headlamp can be very bright. Especially on a close up. You may need to play with the mouth if it used any type of shader settings other than default......
    Kat
  • Silas3DSilas3D Posts: 770
    Only benefit of having NVIDIA cards is speed, otherwise they are the same.
    No disrespect Spooky, but you speak as if this is a minor consideration - speed is of the essence to many 3D artists, particularly if multiple projects are on the go. Therefore any significant increase in speed to provide the same result is in itself, significant.
  • AdemnusAdemnus Posts: 744
    ug, it just crashed and upon restarting has re-docked all of my tabs that I'd just moved to my second monitor. I guess I should have hit save somewhere lol. Also, I had tried rendering a sky dome (scene only setting, using Predatron's skies) with Urban Sprawl and it just came out black and then crashed lol
    Sky domes cast shadows. You can light the dome by making it an emissive surface, or remove it.
    So what you're saying is that bundle of 20 skydomes I bought from new releases, because I was certain they were offered because of Iray, was a bad idea lol
    Gotcha. I will be working today with the photometric spots and PLs in ds. Quick question;
    Under Nvidia Iray I can choose cpu and or my nvidia card. Should I check 1 or both?
    edited March 2015
    OK....
    I did not find it... as you can see in the Screenshot the Scene Tab does not provide a Camera and the Parameter Tab also did not provide a Camera.
    1920 x 1080 - 205K
    Post edited by R25S on
  • SimonJMSimonJM Posts: 6,076
    I thought the mouths (at least) of the Big Cats used a custom shader, so that would not translate (well) to Iray?
    Speed is definitely a huge perk. But we have several people concerned that they can not use the features at all if they do not have a supped up Nvidia card. This is to reassure them that the only thing they miss is added speed. The settings and render results are exactly the same. :)
    Kat
    edited March 2015
    Depends on your card. If you have a single beefy GPU, or multi-gpu (non-sli) then uncheck the CPU, as Sickle pointed out in another thread, enabling the CPU when your GPU is capable it can slow things down. Why I have no idea, I'm not that technical with PBR.
    I'm running a single EVGA GTX 770 4GB FTW Edition and I've unchecked CPU and I've been fine, but then I've only been doing single figures and the lighting. I haven't set up a full scene yet.
    Post edited by Lissa_xyz on
    They use Texture Maps; I don`t know if they use Shader, too.
  • BeeMKayBeeMKay Posts: 7,019
    Sorry if this has been asked before... I have a Geforce GTX 660, which should be able to support CUDA. I'm running the 4.8 64 bit version on a Win7 system.
    IRay works fine when I run it via CPU, but when I use the graphic card, it gives me a "black screen" output render.
    Any idea what the problem might be?
  • Richard HaseltineRichard Haseltine Posts: 109,082
    My recollection is that MB2 uses a custom shader on the moth - it was a problem in one of the other alternative renderers too as I recall. It may be that the parameters simply aren't named in a way that allows them to eb picked up and converted, in which case you may need to make a note of them and then apply them to a standard shader for use in Iray. if that is it, please make a report as the base would need to be updated somehow to work with Iray.
    edited March 2015
    And if you need more speed, you can throw hardware at it. If you really want speed you can throw an NVIDIA VCA at it.
    If you don't throw hardware at it, for most scenes, providing you properly light your scene in 3Delight, the render times are, on average, the same. You have lost nothing in terms of speed, but gained the ability to increase your speed by throwing money/hardware at it.
    Comparison. Same computer. Lit by a single HDRI, in the 3Delight render the HDRI was placed on an Uber Environment 2. Same hardware, same HDRI map. The Iray render took 18 minutes, 23 seconds. Iray (CPU only), the 3Delight image took 72 minutes 12 seconds. (Note this is a straight load and render, no changes were made to the surfaces.)
    Is it worth the extra wait time?
    1000 x 1300 - 1M
    1000 x 1300 - 914K
    Post edited by DAZ_Spooky on
    Depends on your card. If you have a single beefy GPU, or even 2 beefcakes in SLI then uncheck the CPU, as Sickle pointed out in another thread, enabling the CPU when your GPU is capable it can slow things down. Why I have no idea, I'm not that technical with PBR.
    SLI is not required. In fact NVIDIA recommends disabling SLI and ECC (High end Quadro and Tesla Cards).
    Maybe that`s the Problem.
    I send a note to the Support.
  • Zev0Zev0 Posts: 7,123
    edited March 2015
    Render I did testing light bounces and lighting. Should have let it cook a bit longer:(
    1000 x 1300 - 1M
    Post edited by Zev0 on
    My recollection is that MB2 uses a custom shader on the moth - it was a problem in one of the other alternative renderers too as I recall. It may be that the parameters simply aren't named in a way that allows them to eb picked up and converted, in which case you may need to make a note of them and then apply them to a standard shader for use in Iray. if that is it, please make a report as the base would need to be updated somehow to work with Iray.Thanks Richard. It is indeed a custom shader.
    edited March 2015
    Under Nvidia Iray I can choose cpu and or my nvidia card. Should I check 1 or both? Sky domes work, if you light them up. :) It isn't difficult to do, but it is something you will have to do to use them.
    Note in most cases, check both for rendering, unless you know the scene does not fit on the video card. :)
    edited March 2015
    Is there a way to shrink skydomes or enviroment maps? Sometimes when using an hdri image it is way to zoomed in, and I cannot fit the entire sky in the viewport.
    Under Environment in Render settings. Note that the light still comes from infinity, but the draw should be the scale you want.
  • RogerbeeRogerbee Posts: 4,460
    First decent one I've seen, everything else looks a bit dull and flat.
    CHEERS!
