Genesis 9 clothing questions & answers
2456711
  • PendraiaPendraia Posts: 3,615
    So I watched the video...thanks very much that looks like a useful process.
    Also had a look at the pdf. Some questions I had in regards to adjustable weight maps for dforce.
    1. What's the best process for adding them? Using the create menu or the simulation settings tab?
    2. The one that gets created in the Create menu adds just dForce Modifier Weight Node in the scene tab in the pdf it looks different. How do you add it so it looks the same as the scene tab?
    Thanks again this is so helpful...
  • MadaMada Posts: 2,044
    edited October 2022
    Its a paintable weightmap layer to paint on when you have poke through after a simulation. If you want to add your own - create a push modifier, add a weightmap in the weightmap tool menu, select all the faces and with the weightmap tool selected  fill all faces with 0% weight - then its paintable. You save it in the clothing by using wearable preset save. :)
    Post edited by Mada on
    thanks Mada...so much help. I'm still exploring this figure is very different. I have found and docked the developer tab which I think will see a lot of use. So much to explore...
    There is a LOT under the hood :D
    Oh yeah! I'm not sure by old brain is up to the task but I'll keep trying. One of my proudest moments recently was when my grandson said to his girlfriend that I knew more about computers than they did. Proud grandma moment...
    Pendraia said:
    I haven't had chance to watch the video but I've had some success which I'm really happy with. I was getting really frustrated yesterday as the process is a little bit different and I was using the transfer utility as I had in the past with poor results but by using the utilities to load the dress template and then using that in the transfer utility I was able to get it to work. Doing a happy dance right now...please ignore the poor render and surfaces. This has no uv's yet. It will be dforce rather than conforming.
    I just needed some distance to get it to work...my brain was in a loop yesterday.
    That's looking great! :D
    One of the things I love about G9 is the rigging - it is now much easier to rig long dresses and skirts with shins. The A Pose from before made anything with a skirt and high heels hard to rig. Now that the feet are standing flat on the ground its much easier to use.
    The ability to load the template is great too - there's a lot of different uses
    1. You can load the template to see how close its going to be to the outfit you're transferring to - the closer it is in volume the better your result.
    2. Creators can load the templates and see where the different clothing zones are to make it easier to fit pants and shirts over each other (not mandatory of course, but useful)
    3. If you have a figure that you use a lot and it includes a custom morph that doesn't work well with clothing, you can fix the morph in the template and save it, and from then on clothing that you autofit will use the morph you fixed.
    4. You can take the template items into MD and drape against them - the plan is to expand the templates with a hoop dress, loose jackets, some high heel templates etc - once the dust settles down a bit.
    5. Last but not least you can use replace source with the templates to get all the custom ercs and formulas hooked up for your dresses - just make sure you immediately save with another name and in another product folder so you don't overwrite the templates.
    thanks Mada! Coming from you that means a lot. Thanks for all the tips! As I become more familiar with doing all this I was planning on creating my own templates also.
  • barbultbarbult Posts: 26,391
    edited October 2022
    I made this simple T-shirt in MD on the base G9. When I dialed in the feminine morph it adjusted perfectly. I was pleased. I used the loose bodysuit template in the transfer utility. I applied a hand knit shader and used the Thicken plugin to give it some heft. She had to wear the essentials bikini bottom, because she doesn't have any other pants yet.
    @Mada, in tip 3 about draping on templates in MD, do you mean we should make avatars from those templates? How do we bring it back into DS to fit the base G9? Do we have to follow the procedure in Josh Darling's video that you linked? Thanks for all the help you are giving us amateurs.
    2000 x 2600 - 3M
    Post edited by barbult on
    Love the tshirt Barbult!
    edited October 2022
    The shirt looks great :)
    You export the template as an obj and import it into MD as an avatar, then drape against it. Then export the garment as an obj to bring into DS and use transfer utility as before. If you're draping against the male or female morph dialed up in the template then you will use the same method as in the video to get the base shape (using G9 of course, not the template).
    Thanks. I believe I understand.
  • TimotheusTimotheus Posts: 249
    The video discusses just a few of those G9 Dev Tools. How do we learn about all the others?
    Tim
    Tim
    I'm not quite sure which ones are included with the general release, I have a lot of custom scripts included in mine. Can you tell me which ones you want to know more about?
    This is what we get in the Developer Tools.
    210 x 430 - 33K
    edited October 2022
    Here's a quick rundown - most are self explanatory and will give info when you click on them
    Select Morph Verts
    Put parameters window into edit mode, select a morph and then run the script - it will select all the vertices used in that morph
    Clear Morph Verts
    Dial up the morph, select it and then use clear morph deltas and it will delete those vertices from the morph
    Clear HD Morphs
    N/A for users
    Remove empty morphs
    If you have empty morphs that came across from templates you can select them in the parameter window and run the script. It will remove all empty morphs.
    Resave with a new folder name so DS create a new data folder without those morphs included. If you simply resave in the same folder those morphs are already in there and will simply reload next time.
    Get Morph Delta Info
    Select a figure/clothing/prop and click the button - If you have no morph selected it gives you a list of everything. If you select any amount of morphs it limits it to the selection
    Texture Convert : Single UDIM to Multiple
    The script is for texture artists...it was easier for our texture artists to work on a single 16k or 8k image so they would export G9 with the single UDIM, texture it, then once they are done they run this script on their images and it breaks them back out into multiple images for use with the multi UDIM UV
    Adjust Eye Rigging
    If your head morph moves the eyes somehow you dial up the morph and select it on G9 with the eyes loaded, then run this script and it will adjust the eye bone position to fit the shape
    Set G9 to Shape
    Select G9, run script and then select the shape you want for base.
    Create follower
    Quickly set up a follower from obj
    Update Follower Base shape
    Select base and run script to change base shape
    Save current pane info
    Saves the position and size of the floating pane
    It would be great if we could learn what ALL of them do. However, I don't expect you Mada to explain them all. LOL
    :P I tried - see above
    Select Morph Verts
    Clear Morph Verts
    Dial up the morph, select vertices you want to delete, favourite the morph you want to work on, click clear morph deltas and it will delete those vertices from the morph
    Clear HD Morphs
    N/A for users
    Remove empty morphs
    Select a figure/clothing/prop and click the button - DS will return a list with all the morphs in the figure, as well as the deltas in each morph, and the HD level of the morph
    Will find out more info, since I don't use it I don't know
    Adjust Eye Rigging
    For character creators - will get more info
    Set G9 to Shape
    Create follower
    Will find out
    This is a great start! Thank you so much.
    Tim
    yesheart
  • lilweeplilweep Posts: 2,760
    would be cool if this automatically splits up the Single UDIM textures into Multiple textures so we dont have to do it in Photoshop or whatever.
    It's a lot easier to bake onto Single UDIM texture in other software, so i usually end up with a single UDIM that i need to split up.
  • DeeceyDeecey Posts: 167
    I'm not sure if this question fits in this thread or if I should ask somewhere else. I'm not quite sure what I'm doing wrong here. 8-)
    So I created this dress for G8 Female. Now I want to see if I can use it on Genesis 9. But the difference in the leg pose (G8F A Pose vs G9 Straight leg pose) causes the dress to bunch up in the middle.
    For more detail:
    When I first drag and drop the dress in and place it on the Genesis 9 base shape it actually looks quite good (Gen9Dress1)
    Then I select the options to tell DS that it was originally created for Genesis 8 Female (Gen9Dress2)
    After the dress is fit, the skirt bunches up between the legs because of the difference in the leg pose (Gen9Dress3)
    Being that Genesis 8 is the only figure I've developed for, I'm not sure what I can do to alleviate that bunching in the middle. Is there some sort of solution that I'm not aware of?
    445 x 648 - 140K
    274 x 194 - 13K
    431 x 661 - 125K
    What I would do in this case (there are other ways for sure but this would be my workflow)  - dial up the G8 clone on G9, load the dress but don't fit the dress to a figure, just have it in the same space as your G9 with the G8 clone dialed so you can see where the legs are.
    Select the thighs on the dress, move them inwards and turn on smoothing to get rid of any crunching. Export that as a base res obj.
    Then follow the steps in the video using G9 with G8 Female as your base, import the dress obj, use the transfer utility with dress loose template - dial up the base G9 and turn on smoothing, then export that.
    Now you can import the dress onto the base G9 and use transfer utility for the loose dress again.
    So basically following the steps above will take your G8 dress, fix the legs, then take the G8 Female shape down to G9 base and then using the template you will get the best fit :)
    Awesome, thanks for the tips!
    I just made public a lot more videos on my channel, mainly to do with creating for Genesis 8 - but Genesis 9 use exactly the same principles :)
    https://www.youtube.com/playlist?list=PL2SdKrOTXeXA1qMgNE84AsM8_Wq63gOBF
    Thank you, love your tutorial videos :-)
    :D Thank you!
    You are wonderfully generous, Mada.
  • DustRiderDustRider Posts: 2,902
    WOW!!!
    Thanks so much, simply awesome of you do do this.
    thank you, was just looking at your old rigid follow node tutorial yesterday
  • jeylienjeylien Posts: 33
    Pancake said:
    jeylien said:
    (after having used transfer utility to fit the G9 G8m clone shape to an actual G8m and then dialing in the HFS Ultimate Shapes morphs for the alien and animal type legs, there were obvious distortions with some vertices between the toes not really matching up well enough to make the morph transfer over), but the everything else including hands, face, eyes, ears-- basically the other typical problem areas-- seems to work really well! So this isn't just useful for clothing, but also transfering morphs from G8. Which is going to enable me to start using G9 much much sooner now. I'm excited!!
    Apologies, where was the tool that allows the use of G8 morphs? I looked in the dev utilities and didn't see anything applicable after clicking around. Though it could be I have something incomplete as i've seen a few people on the forum talk about having partial downloads.
    Sorry I didn't get back to you sooner, just noticing this now --
    There is no tool (yet, that I know of) that allows the use of G8 morphs on G9. However if you're familiar with the use of the Transfer Utility in Daz Studio, and if there's a clone shape in the figure you're wanting to transfer to (in this case G9) for the figure you're wanting to get the morph from (G8 male or female), there is a process you can try, and which is applicable to basically any generation of genesis figures if you have the respective clone shapes. SickleYield gave a good tutorial some years back, here: https://www.deviantart.com/sickleyield/journal/Tutorial-Transferring-Character-Morphs-G1G2G3G8-409437916
    In short summary, what you have to do is: (1) load the figure you're wanting the shape to be on (again G9); (2) dial up the clone shape of the figure the morph is for (G8 m or f, this requires making hidden parameters visible in the parameters pane, and probably doing a search for "genesis 8"); (3) set figure to base resolution; (4) export as obj; (5) load the figure that has the morph you want (here G8); (6) import the obj of the other figure in the clone shape; (7) use the Transfer Utility to fit that obj to the source figure; (8) dial up the morph you want on the source figure, the fitted obj mesh should follow and display the shape too with varying levels of accuracy; (9) hide the source figure, export just the fitted obj mesh which should now have the morph shape from the source, export as new obj; (10) clear the scene, load your target figure (in this case G9); (11) use Morph Loader Pro to use the morphed obj from step9 to now create a morph for the target figure you want. If all goes well, you'll get a passable base-res version of the morph from the other figure, onto the figure you want. :)
