Victoria 9 Hd Makeup
PetraPetra Posts: 1,157
edited October 2022 in The Commons
I have problems with this product.
When I add the single textures it works good * takes ages to apply * but, when I want to use the apply all, it does look wrong.
The first Image is an  example where I used V9 Makeup Apply All 02.
And the second one is how it should look like.
Loading time for all the Makeup options are quite long.
None of the Removal options work.
Has anyone else the same problem with this product?
When I clicked on the redo button to remove the Apply ALL option, it changed the skin of V9 to the Freckle one.
Post edited by Petra on
  • SevrinSevrin Posts: 6,313
  • PetraPetra Posts: 1,157
    Thank god, it is not just me.
    I put a ticket in to Technical support.
    Do you also have those long loading times for most of the G9 stuff, mostly V9?
    I wonder if it might be the latest Driver, I downloaded it yesterday, it is a Studio Driver.
  • GoggerGogger Posts: 2,499
    If you are referring to adding the makeup taking a long time, that is a 'feature' of using LIE. It has ALWAYS taken a bit, all the way back as far as I can remember.
  • felisfelis Posts: 5,902
    It was suggested that you go to Preferences > Interface > Layered textures: to speed.
  • LIE is the tool for editing Layered Images, and yes Layered Images can be very slow - however, if you look at the chnage log you will see that work has been and is being done on both areas.
    chevybabe25 suggested setting it all the way to the left, which I think is compression, not speed. I don't have DS open atm. LOL
    FWIW, it does speed it up a bit when you pull the slider all the way to the left :)
    All the way to the left, a value of -1, is the default, previous, behaviour. See http://docs.daz3d.com/doku.php/public/software/dazstudio/4/change_log_4_21_0_5#4_20_1_75
  • KeikuKeiku Posts: 143
    edited October 2022
    It takes forever for me also. Just about everything with G9/V9 seems much slower. Sometimes the makeup options don't apply, undo doesn't seem to always work and the remove options don't work for me either.
    Post edited by Keiku on
    What Slicer are we talking about?
    Thank you for your reply.
    I feared I did something wrong, and then I thought maybe it was the Studio Driver I updated too.
    But it is true, everything is loading painfully slow with G9.
    I put in 2 Tech Support tickets earlier.
    One for the Error Message when loading G9 and V9 and the other one for the Makeup situation.
    Under preferences. Interface tab - Layered Textures (near the bottom of the window). I tried it both ways. First I set it all the way to the right and had all kinds of difficulties. Then I slid it all the way to the left and LIE was much quicker than it was. **shrug** It's just my experience and yours may vary :)
    Thank you so much for your help and quick reply.
    I will try to set it all the way to the left.
    Will it change the render quality at all?
