Why do I keep needing to install?
Daz Central constantly marks products, some years old, as needing to be installed, even though said products are installed and usable in Daz? Why is this?
  • SofaCitizenSofaCitizen Posts: 2,135
    I don't use Daz Central but have you ever allowed DazStudio itself to connect/login? If so then the Daz Connect from that process is likely causing conflicts in the same way it does for those of us who use DIM for installation.
  • Updates?
  • brimstoneomegabrimstoneomega Posts: 343
    edited October 2022
    No, it's not updates, I think it's some kind of bug... I think. I've had this happen to me before, it's like some random stuff, the default resources, ext. I believed the pop-up the first few times and just reinstalled everything. Now I just ignore it.
    I think it's from having multiple install options used and multiple drives/ custom folders. I could be wrong. But it's a false warning. At least for me, and also looks like the OP.
    Narrowing down and addressing the bug would be difficult, I always thought it was just me or something I did, but the bug I encountered seems to be about the same as OP's bug.
    Edit: Side note, I don't get this with Central, but with DIM, and while it used to happen relatively frequently, it has pretty much stopped lately.
    Post edited by brimstoneomega on
  • Worse now. I just discovered that Mesh Grabber is compleatly gone.
  • PetercatPetercat Posts: 2,321
    Don't feel alone. I've had several products disappear from my computer. I came here to re-download Classic Tuxdedo for G3M because I just discovered that it is no longer on my computer. This happens at random, it seems.
  • For me Daz Studio was worst on that. All sorts old and new products kept showing under updates...
    So i switched to DIM and run Studio offline now. Installation isn't fully clean though, as i did DIM and then some Studio due to something not working for a moment in DIM. So at some point i will probably redo that all once more.
  • jmtbankjmtbank Posts: 188
    Might be worth installing 'problem' products via DIM.
