Where is Install Manager putting my content? [Solved]
EZ3DTV
I have my install directory set but it seems like the Install Manager has opted to put the content somewhere else.
Post edited by EZ3DTV on
Why is the install Manager putting my content here instead?
C:/Users/Public/Documents/My DAZ 3D Library
I figured it out, there is a drop down menu hidden that I needed to select the right folder.
"Content Path Shortcuts"
General advice (if you're on PC), install Voidtools Everything. It's a MUST install tool.
Organize Everything's blazing fast indexation by : Date Modified. This way you see the files being modified/created in real time at the top of the list of all your files, anywhere in your hard drive or your mapped Cloud drives.
Install Everything, and you'll never wonder where are your things, what's installed, where, etc.
Install Manager can have multiple paths set, but only one active at any time. if you check Show Details at the bottom of the main window you can shoe and chnage the current active path, from those DIM has been told about, but you can also go to Advanced Settings from the gear icon and in the Installation tab make one directory the active/default.
