Daz Keeps Applying/Changing Certain Silders automatically from different characters
Hi All,
I'm new to daz, I am having a strange issue.
Whenever I load a character(bought from Daz store) sliders from other characters are applied. If you see the screenshot the character loaded onto the studio is Sefforah but EQ Quig Head is set to 100, same goes for all other parameters as seen in 2nd screenshot, this is not requrired at all and it's automatically set to 100 for every single character which I load. Anyone shed light on this?
If the proerpties were saved with non-zero values this will happen - check to be sure you are using the current version of the affected characters, and if you might have used the Save Modified Assets command you may want to try reinstalling. Any characters saved in this way should be reported to Daz (if they are from the store; I am not finding an EQ Quig) or the creator, but you can fix them yourself for Genesis 8/8.1:
