How to register multiple objects as prop assets?
flare_dbd185b4ba
Hello,
In my understanding, prop assets are individual parts, and scene assets are created by placing prop assets, lights, cameras, etc. in the scene.
If this understanding is correct, I don't think there is a way to register multiple props that have a parent-child relationship as prop assets. Am I wrong?
A friend said that there is a way to register multiple objects together as a prop asset, but is there such a method?
Thank you.
One prop asset can only consist of 1 item.
You can parent items to each other and save as a scene subset.
Or you can rig an object to have more parts.
But it is not clear to me what you are trying to obtain.
Scene subset nad figure/prop Asset are different things. A scene can contain assets that have not been saved, but usually it is pointing to assets (objects and rigging, textues, shaders etc.) A wearables preset or a scene will save hierarchcial relations; you can also use a post-load script to handle such things. File>Save As>Support Assets>Scene Assets is the only way, that i know of, to save multiple assets in one go.
I'm currently learning to distribution props with multiple objects on Daz and would like to know the correct way to register each asset.
For example, if you want to distribution a faucet and tap water set, is the following file structure correct?
Props ......................... Props with faucet and water objects placed at the origin are individually registered as prop assets.
Scene..................Place a water prop in the faucet and register it as a scene asset with lighting and cameras set.
thank you.
My understanding is correct.
thanks for your advice.
