Daz Studio Iray - Rendering Hardware Benchmarking
1313234363747
  • System Configuration
    System/Motherboard: ASUS PRIME X299-A
    CPU: Intel Core i7-9800X @ 4,000 MHz
    GPU: ASUS TUF Gaming GeForce RTX 4090 OC Edition 24GB GDDR6X @ stock
    System Memory: Kingston HyperX Predator RGB 64GB (4x 16GB) DDR4 @ 2,666 MHz
    OS Drive: Samsung 970 Pro 1TB
    Asset Drive: Same
    Power Supply: Seasonic PRIME Ultra Titanium SSR-850TR 850W
    Operating System: Windows 10 Enterprise 10.0.19044.2130
    Nvidia Drivers Version: 522.25 WDDM
    Daz Studio Version: 4.16.0.3 x64
    Optix Prime Acceleration: N/A
    Benchmark Results
    2022-10-14 21:05:43.633 Finished Rendering
    2022-10-14 21:05:43.669 Total Rendering Time: 1 minutes 1.40 seconds
    2022-10-14 21:05:51.792 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Device statistics:
    2022-10-14 21:05:51.792 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 4090): 	 1800 iterations, 2.249s init, 56.620s render
    Iteration Rate: 31.79 iterations per second
    Loading Time: 4.78 seconds
    Asset Drive: Same
    Daz Studio Version: 4.21.0.5 Public Beta x64
    Benchmark Results
    2022-10-14 22:16:02.728 [INFO] :: Finished Rendering
    2022-10-14 22:16:02.761 [INFO] :: Total Rendering Time: 1 minutes 24.40 seconds
    2022-10-14 22:16:10.030 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Device statistics:
    2022-10-14 22:16:10.030 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 4090): 1800 iterations, 1.335s init, 80.701s render
    Iteration Rate: 22.30 iterations per second
    Loading Time: 3.70 seconds
  • johndoe_36eb90b0 said:
    outrider42 said:
    System/Motherboard: X570 AORUS ELITE
    CPU: AMD Ryzen 9 5900X @ 3700 Mhz
    GPU: Gainward Phantom GS Nvidia RTX 4090
    System Memory: 64 Gb
    OS Drive: SSD 2 Tb
    Power Supply: 1000W
    Operating System: Windows 10 family
    Nvidia Drivers Version: 522.25 Game Ready
    Daz Studio Version: 4.21.0.54 Public build Beta 64bits
    Optix Prime Acceleration: On
    Benchmark Results
    Total Rendering Time: 1 minutes 23.12 seconds
    IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 4090): 1800 iterations, 1.466s init, 79.788s render
    Iteration Rate: 22,56 iterations per second
    Loading Time: 3,33 seconds
    Are these numbers correct?
    If they are, then clearly there is a problem because the 4090 here only matches a 3090ti at best. So that is honestly a terrible result.
    But on the bright side at least card is functional! That is tremendous news as I was really concerned it would not work at all. But still, this shows that we really badly need an update for Iray and Daz Studio that makes these cards work properly. While it may have worked for the benchmark scene we have, it may have problems in other scenes.
    For example, does dforce work on the 4090? Dforce always needs to be recompiled for new hardware. There is also the denoiser, and any number of other plugins. There could be glitches and issues until we get a proper update.
    I can explain his result because I also got RTX 4090.
    Card does not pull more than 285 W when rendering in Daz Studio (tried both 4.16.0.3 Release and 4.21.0.5 Beta) which means the Iray code is not optimized yet for new architecture.
    That isn't an explanation of anything, Iray does not use all featues of the card and there is no reason to expect it to push the power draw to the maximum.
    dForce is broken completely in 522.25 Game Ready and Studio driver (OpenCL related errors).
    Finally I have to correct you on one thing -- RTX 4090 can absolutely pull 600W.
    My card has default 450W power limit which can be raised to 600W using nvidia-smi -pl 600 command. I have tested mine, and I got it to pull 565W in Furmark Stress Test in 1080p.
    WARNING: Only try changing the limit to 600W if you have at least 850W power supply (more if you have 12th or 13th gen Intel CPU), preferably with the new 12VHPWR connector (which guarantees 100% power excursions for 100 us intervals) or if you have a really high quality recent power supply like say Seasonic SSR-850 with 4x 8-pin PCI-E cables connected to the adapter cable you get with the card. Needless to say, not all cards and VBIOS-es are going to support such a large power increase (mine is ASUS TUF Gaming GeForce RTX 4090 OC Edition 24GB GDDR6X so it does), and you are going to want a really big and well ventilated case if you plan running that for more than a few minutes at a time.
    OS Drive: SSD 2 Tb
    Power Supply: 1000W
    Benchmark Results
    With RTX 3090, both Daz Studio versions easily hit 330W out of 350W limit (~94%).
    With RTX 4090, both Daz Studio versions are hitting 285W out of 450W limit (~63%).
    In both cases GPU utilization is 100%, but it is clear that RTX 4090 has hit some performance bottleneck due to architectural differences or it would be pulling a lot more power.
    Look at it this way -- you can have 100% CPU utilization calculating number PI using SuperPI software which uses legacy x87 floating point instructions or you could have 100% CPU utilization doing the same calculation using AVX512 SIMD units. I will let you guess which one is going to use more power despite showing the same 100% CPU usage.
  • RaketeRakete Posts: 93
    ~31 iterations per second at 285W does not sound bad at all. And just going from there to a theoretical 100% of power consumption would end up being ~50 iterations per second. Though I assume it would not scale that well, also, I guess we'll never find out because only the new slower Iray (I actually did not know it is that much slower, I simply kept using 4.16 because I am too lazy to switch my mesh lights) will be updated to take full advantage of the new architecture. Well, maybe they'll also fix the performance bottleneck then, otherwise it does feel like we got cheated out of a lot of potential performance.
    The 22 iterations at 285W would be 36 iterations at 450W, pretty good as well, but considerably less then 50.
  • RayDAntRayDAnt Posts: 1,156
    edited October 2022
    Not exactly. Iray makes FULL use of a supported GPU's internal processing resources (including Tensor cores when ai denoising/upscaling is active) - hence why you see ~100% GPU activity during rendering. The reason for the markedly lower power draw than - say - 100% GPU activity during gaming is because of the lack of outside-of-gpu processing needed on the card's part to do it's thing. Game rendering necessitates maintaining a constant stream of fresh data coming from the CPU over the PCI bus that the GPU has to unpack and integrate into it's processing pipeline. And that sort of constant high bandwidth data transfer takes real watts to accomplish.
    Once Iray finishes loading in scene data and starts the actual rendering process, the high bandwidth work is done. Hence the lower watts observed. And why those watts will never be as high as seen in gaming. No matter how optimized Iray is for running on specific generations of Nvidia hardware. Unfortunately those reduced wattage numbers aren't something that you will be able to turn into a rendering performance uplift with some hidden performance tweak later on.
    Post edited by RayDAnt on
    Not all 100% usage is equal. It only takes one aspect of the GPU hitting its max to get a 100% report. The report of 100% is not specific to what it is that is getting bottlenecked. There are many components on these GPUs, they are like their own mini computer within a computer (though they certainly are not so small anymore.)
    This card should not be running 285 Watts in Iray. This stat alone is a sign of a bottleneck of some kind. As the 4090 should be running higher than that for rendering.
    That goes against every other rendering software out there, and the performance indicates this is not quite right, either. The 4090 doubles the 3090 in most render applications, and sometimes does more than double. Puget ran their bench suit, and the 4090 manages this in every rendering test. They even tested with two 3090s in many of these tests.
    https://www.pugetsystems.com/labs/articles/NVIDIA-GeForce-RTX-4090-24GB-Content-Creation-Review-2374/
    Check out Vray, they have RTX enabled and a CUDA only mode. The CUDA only mode is interesting, and even with only CUDA cores, the 4090 still out performs two 3090s.
    (It is wild to see the 2080ti at the bottom of these charts.)
    This is a direct quote from the article:
    "GPU rendering is really where you are going to get the most out of a more powerful GPU, and the RTX 4090 comes through in spades. GPU Rendering is often nearly twice as fast as the previous generation RTX 3090 or 3090 Ti, or four times faster than the older RTX 2080 Ti."
    Iray traditionally is right there with these render engines when it comes to generational performance gains. So everything is pointing to something being off.
    It shouldn't be a surprise. The surprise is that Lovelace even works at all. Iray is using CUDA 11.2.2, but Nvidia's own documentation specifically state that CUDA 11.8 is REQUIRED to run CUDA on Lovelace. So this statement, combined with the benchmarks and data we have all indicate that the 4090 should be running faster in Iray. Much faster. My guess is that Iray is giving the 4090 instructions not designed for it, the 4090 has new features previous cards do not have. So without these instructions, you have transistors just sitting there doing nothing. The rest of the GPU can be working hard, the parts it shares in common with Ampere's design, thus the 100%, but the new parts are basically idle because nothing is telling them what to do.
    It is like the hiring a bunch of new people, but not telling them what to do. The old staff are still working hard, but the new staff wonder around doing nothing. When the boss finally gives them instructions on what to do, the team will begin to work faster as a group (hopefully). That is the 4090 right now with Daz Iray.
    In other news, the 4080 12GB can unlaunched (Nvidia's words, not mine.) It got cancelled. Surprise! So the 4080 16GB is now the only other Lovelace launching that we know of. What this means for the rest of the product stack is anybody's guess at this point. This move is pretty unusual to say the least. Then again, the 4080 12GB was pretty strange to begin with, I am glad they called it off. They should never have named it that, but that is another discussion.
    Where did you see them saying this, if I may ask? Because based on my own reading of official Nvidia documentation (the Cuda Best Practices Guide to be exact) the exact opposite is the case due in large part to the Binary Compatibility paradigm they are currently adhering to (which also doubles as the technical explanation for why Lovelace GPUs are already being successfully used with Iray versions that theoretically don't support them yet.)
    Sort of. Unlike the jump from Pascal (10XX) to Turing (20XX) GPUs back in 2018, most - if not all - of the hardware upgrades seen in the Ada die design over its predecessor are concerned with better/more optimized management of existing physical processing pipelines (aka cuda/rt/tensor cores and the like) rather the introduction of brand new ones. So rather than thinking of it as there being certain parts of the GPU die not being used, it's more that there are certain parts of the GPU die that can now be used simultaneously as other parts or even for multiple purposes - that prior Cuda software versions simply don't know about.
    Very well. I was wrong. I can admit to being wrong about something, unlike some.
    I wouldn't be so sure that simultanious instructions add over 100 Watts to power draw. That seems excessive to me, there has to be more to it than that.
  • @RayDAnt, @outrider42
    Ada Lovelace CUDA capability version has been bumped to 8.9.
    It means that in order to fully utilize new capabilities, existing CUDA code (OptiX / Iray) will have to be recompiled using CUDA Toolkit 11.8 nvcc compiler.
    Even though it is possible to have binary compatibility by compiling for lowest common denominator that will never work optimally and be able to fully utilize an architecture.
    The same is with CPUs -- you can optimize for Core architecture, but that code will perform worse on Netburst and vice versa.
    Ada Lovelace architecture is different enough to require specific targetting. CUDA executables can contain code for more than one architecture, you just need to specify which ones you want and the compiler will generate different versions of the same kernels for different architectures tailored to their resources (caches, shared memory size, number of SMs, block size, thread count, etc, etc).
    What I expect to happen is a new OptiX release followed by new Iray and new driver release. Only then we will see the true speed and power draw.
    Just an fyi that I am actively refraining from incorporating any benchmark data from Ada Lovelace series GPUs into the tables at the top of this thread until official Iray support arrives. In the meantime, keep posting interim 4090 testing results if you've got them. It's still useful/interesting info to have imo.
  • System/Motherboard: X570 AORUS PRO
    CPU: AMD Ryzen 7 5800X @stock
    GPU:RTX 2070 Super @stock
    System Memory: Corsair VENGEANCE 32 GB @ 3600MHz
    OS Drive: Samsung 980 PRO Gen.4, 500GB, NVMe
    Asset Drive: Seagate Expansion Desktop 4TB
    Power Supply: Corsair TX550M, 550W
    Operating System: Windows 11 Pro 22H2
    Daz Studio Version: 4.20.0.17 64-bit
    Benchmark Results
    2022-10-18 01:15:22.677 [INFO] :: Finished Rendering
    2022-10-18 01:15:22.700 [INFO] :: Total Rendering Time: 4 minutes 49.25 seconds
    2022-10-18 01:15:33.833 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Device statistics:
    2022-10-18 01:15:33.833 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 2070 SUPER): 1800 iterations, 1.305s init, 286.126s render
    Iteration Rate: 1800/ 286.126 = 6.29 iterations per second
    Loading Time: 289.25 - 286.126 =  3.124seconds
    I hope I did this the right way :)
  • AndyAkinsAndyAkins Posts: 45
    edited October 2022
    So, I upgraded. It was just the right time, I was able to find a 4090 unlike when the 3090s came out, and I had the funds. The main thing I wanted was more RAM - but obviously a speed increase would be nice too...
    My original:
    System/Motherboard: Gigabyte B550 Vision D
    CPU: AMD Ryzen 9 3900XT stock
    GPU: GIGABYTE GeForce RTX 2080 SUPER GAMING OC WHITE 8G / stock
    System Memory: Corsair Vengeance RGB Pro 64GB DDR4 3200 stock
    OS Drive: Samsung SSD 970 EVO 1TB
    Asset Drive: Samsung SSD 970 EVO 1TB (identical, but separate from OS)
    Power Supply: Corsair HX1200i, 1200 Watt Platnium
    Operating System: Windows 10 Pro 21H2
    Nvidia Drivers Version: Studio 517.40
    Daz Studio Version: 4.21.0.5 Pro Edition 64-bit
    Benchmark Results
    Total Rendering Time: 5 minutes 56.8 seconds
    rend info : CUDA device 0 (NVIDIA GeForce RTX 2080 SUPER): 1800 iterations, 8.921s init, 344.948s render
    Iteration Rate: 5.22 iterations per second
    Loading Time: 11.852 seconds
    And after the upgrade - everything is the same except the GPU:
    GPU: GIGABYTE GeForce RTX 4090 Windforce 24G / stock
    Nvidia Drivers Version: Studio 522.25
    Benchmark Results
    Total Rendering Time: 1 minutes 32.94 seconds
    rend info : CUDA device 0 (NVIDIA GeForce RTX 4090): 1800 iterations, 8.432s init, 82.253s render
    Iteration Rate: 21.88 iterations per second
    Loading Time: 10.687 seconds
    So, not sure if those are necessarily good numbers - but I'm pleased. 4-5x the speed and more VRAM for bigger scenes.
    It should be noted that my 4090 was running at about 275W according to  HWInfo64, so all the comments above re: non-optimal GPU usage would seem to be correct.
    Post edited by AndyAkins on
  • 2x3080s getting me 28 iterations per second, going to watch this space and see if the 4090 can blow that over when it is fully utilized.
  • 3DMinh3DMinh Posts: 286
    edited October 2022
    Hi,
    I would like to ask the people that got the RTX 4090, besides the Dforce issue, do you have any other problem while using Daz Studio with the new card?
    I got a very good deal on the 4090 in my country so I'm temping to buy one right now and sell the old card. I don't use Dforce anyway.
    Thank you very much.
    Post edited by 3DMinh on
    I already posted my benchmark with Daz Studio 4.16.0.3 which gave me 31.79 iterations per second so you don't have to wait for it to even be fully utilized -- it is already faster, at least in 4.16.
    There is some flickering on transparent surfaces (eyelashes, etc) when zooming and panning in Iray preview, other than that nothing major and dForce will be fixed eventually.
    One iteresting tidbit, while playing older games like say Mass Effect 3 (Legendary Edition) on 4090 in 1080p the GPU clock varies between 210 and 795 MHz, and RAM between 50-100MHz while the temperature is 40 degrees Celsius. It is ridiculous how little power the card needs to run the game. If nothing else, it can run simpler stuff much more efficiently and pretty much silently.
    System/Motherboard: ASUS X99-Deluxe II
    CPU: Intel Core i7-6950X @ 4.2 Ghz
    GPU: 2 x NVIDIA Titan X, GP102 Pascal, 12GB/Stock, GeForce GTX SLI BRIDGE @ SLI
    System Memory: 8 x 8GB DDR4-2666, Corsair Vengeance LPX black, Rev S @ 2666Mhz
    OS Drive: 512GB Samsung 950 Pro, M.2 PCle
    Asset Drive: 1TB Samsung 850 Pro Series, SATA3
    Power Supply: 1200W - Corsair Professional Series HX1200i, 80Plus Platinum
    Operating System: Windows 10 Pro 22H2 19045.2130
    Nvidia Drivers Version: 522.30
    Benchmark Results
    Total Renderingtime 4:19 = 259 sec
    1800 IRAY Iterations
    Rendering Performance: 6,94 [DEVICE_ITERATION_COUNT(sum of all values) / DEVICE_RENDER_TIME_(largest value)] iterations per second
    Loading Time:? [(TRT_HOURS * 3600 + TRT_MINUTES * 60 + TRT_SECONDS) - DEVICE_RENDER_TIME_(largest value)] seconds
    Loadindtime ist unclear to me. From Open to workable scene? 13 sec.
    The scene does not max out the hardware. runing about 70% (Complxe scenes run at 100% e.g. 4,2 Ghz).
    Benchmark Results
    Total Rendering Time: 4 minutes 20.93 seconds
    2022-10-21 17:10:16.418 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Device statistics:
    2022-10-21 17:10:16.418 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 1 (NVIDIA TITAN X (Pascal)): 809 iterations, 1.613s init, 256.166s render
    2022-10-21 17:10:16.419 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (NVIDIA TITAN X (Pascal)): 868 iterations, 1.453s init, 256.189s render
    2022-10-21 17:10:16.419 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CPU:                                     123 iterations, 0.891s init, 256.669s render
    Rendering Performance: 6,898 [DEVICE_ITERATION_COUNT(sum of all values) / DEVICE_RENDER_TIME_(largest value)] iterations per second
    The help file reports 2 times in its log. The Total Time includes loading, so we don't want that. Then you should see on the line that reads 1800 iterations, on that line there is a "__.___s render" with number in those blanks. That is your actual render time in seconds. Just subtract this from total render time and you have the loading time.
  • @m43foto11 Here's how the math works out for you...
    Your Total Rendering Time: 4min 20.93sec = 240sec + 20.93sec = 260.93s
    Your 3 individual Actual Rendering Times:
    CUDA1   256.166s
    CUDA0 + 256.189s
    CPU   + 256.669s
    TOTAL = 769.024s divided by 3 = 256.341s average
    Total Redering Time - Actual Rendering Time:
      260.930s
    - 256.341s
    = 4.589s = Loading Time
    Total Rendering Time - Loading Time:
      260.930s
    -   4.589s
    = 256.341s = 4min 16.341sec
    edited October 2022
    CUDA1   256.166s
    CUDA0 + 256.189s
    CPU   + 256.669s
    Fwiw (we're talking literal milliseconds here) it is the only the longest actual rendering time that's relevant here (since that is what dictates how long the rendering prcoess completes as a whole.) Not an average in multi GPU/CPU situations. So in this case the math would be:
    Total Rendering Time - Longest Actual Renderring Time = Loading Time
    or
    260.93 seconds - 256.669 seconds = 4.261 seconds
    so
    Loading Time: 4.261 seconds
    Also fyi @m43foto11 your rendering performance number should be 7.01 iterations per second, since:
    Rendering Performance: 1800 / 256.669 = 7.01
  • robertswwwrobertswww Posts: 799
    edited October 2022
    @RayDAnt Thanks for pointing that out, as I forgot it's just the longest actual rendering time, and not the average.
    @m43foto11 If you don't use your CPU for rendering and only use your 2 x nVidia Titan X GPUs, then you could bump up your Rendering Performance to at least 7.0261 iterations per second (1800 / 256.189s). smiley
    Post edited by robertswww on
  • In my country the price for the RTX 4090 model that I purchased 10 days ago for 2,338 USD has already went up to between 2,524 USD and 2,544 USD.
    If any of you plan on upgrading, do it soon, because it seems they are in short supply and the prices don't seem like they will be going down soon.
  • I'm feeling more and more irritated by the slow down in rendering performance from each new version of DS.
    Back when this thread first started, I put together an Excel sheet to calculate iterations based on the formula given by RayDAnt.  A while later, I started keeping the test run data in there, which means I can go back and compare.  Today, I ran a few more benchmarks on the nVidia 517.48 drivers.
    System/Motherboard: ASUS X99-S
    CPU: Intel i7 5960X @3GHz
    GPU: Zotac 3090 RTX + EVGA 2080Ti
    System Memory: 32GB KINGSTON HYPER-X PREDATOR QUAD-DDR4
    OS Drive: Samsung M.2 SSD 960 EVO 250GB
    Card Nvidia Driver Version Iterations Total Time /s Iteration Rate /s Time / hr Time / min Time / Sec System Overhead Iteration Rate Calc System Overhead
    3090 471.11 4.15.0.2 1800 93.066 19.34111276 0 1 41 7.934 (1800/93.066) = 19.341 iterations per second ((0+60+41)-93.066) = 7.934 seconds
    3090+2080ti 471.11 4.15.0.2 1800 65.4 27.523 0 1 16.7 11.3 (1800/65.4) = 27.523 iterations per second ((0+60+16.7)-65.4) = 11.300 seconds
    3090 511.79 4.15.0.2 1800 93.19 19.315 0 1 38.28 5.09 (1800/93.19) = 19.315 iterations per second ((0+60+38.28)-93.19) = 5.090 seconds
    3090+2080ti 511.79 4.15.0.2 1800 64.97 27.705 0 1 11.7 6.73 (1800/64.97) = 27.705 iterations per second ((0+60+11.7)-64.97) = 6.730 seconds
    3090 517.48 4.15.0.2 1800 93 19.355 0 1 39.78 6.78 (1800/93) = 19.355 iterations per second ((0+60+39.78)-93) = 6.780 seconds
    3090+2080ti 517.48 4.15.0.2 1800 65.8 27.356 0 1 11.53 5.73 (1800/65.8) = 27.356 iterations per second ((0+60+11.53)-65.8) = 5.730 seconds
    3090 511.79 4.20.02 1800 108.8 16.544 0 1 52.1 3.3 (1800/108.8) = 16.544 iterations per second ((0+60+52.1)-108.8) = 3.300 seconds
    3090+2080ti 511.79 4.20.02 1800 74.01 24.321 0 1 17.79 3.78 (1800/74.01) = 24.321 iterations per second ((0+60+17.79)-74.01) = 3.780 seconds
    3090 517.48 4.21.0.5 1800 127.24 14.146 0 2 10.55 3.31 (1800/127.24) = 14.146 iterations per second ((0+120+10.55)-127.24) = 3.310 seconds
    3090+2080ti 517.48 4.21.0.5 1800 87.1 20.666 0 1 31.92 4.82 (1800/87.1) = 20.666 iterations per second ((0+60+31.92)-87.1) = 4.820 seconds
    So both cards, from 4.15 to 4.20 I have lost 3 iterations/second.
    From 4.20 to 4.21 I have lost a further 4 iterations/second.
    About an increase of 20 seconds on the benchmark from 4.15 to 4.21.
    What worries me is that this is unlikely to change because if someone upgrades from say a 3090 to a 4090 and is expecting a 2x increase in iterations/sec, but gets a 1.8x increase, they are not going to complain because it's still faster and you can't completely predict the exact increase.  But it could still be faster if iray or DS wasn't slowing down with each version. I am looking forward to seeing what the 4090 cards can do once DS/iray is updated specifically for them but it's not looking good for people who can't afford to upgrade.
    I've tried Genesis 9 out on DS 4.15 and it seems ok.  I'll have to do some quality comparisons between 4.15 and 4.20 to see what difference there is, but for most rendering I'll be sticking with 4.15 as long as possible.
    System/Motherboard: TUF GAMING X670E-PLUS
    CPU: AMD 7900x (stock)
    GPU: GeForce RTX 4090 GAMING OC 24G (stock)
    System Memory: Corsair VENGEANCE 64GB (2x32GB) DDR5 DRAM 5200MHz
    OS Drive: Seagate FireCuda 530 4TB Internal SSD NVMe
    Asset Drive: Using the same drive as above.
    Power Supply: GIGABYTE UD1000GM PG5 (1000 watt PSU)
    Operating System: Windows 10 PRO version 21H2 build 19044.2130
    Nvidia Drivers Version: 522.25 OCT/12/2022
    Daz Studio Version: DAZ Studio 4.21 (Win 64-bit)
    Benchmark Results
    DAZ_STATS
    2022-10-22 00:20:42.241 [INFO] :: Total Rendering Time: 1 minutes 25.18 seconds
    IRAY_STATS
    2022-10-22 00:22:08.280 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 4090): 1800 iterations, 0.770s init, 82.873s render
    Iteration Rate: 21.719 iterations per second
    Loading Time: 3.169s
    Seems like my results are very similar to what everyone else is getting.
    Yes, ~10 iterations per second less than with Daz Studio 4.16.0.3 Release.
    What is the best version of Daz Studio for rendering speed? I have the previous versions of daz studio, but I don't know which to install. Is version 4.16.0.3 better than 4.15 ? Is from 4.16 to 4.20 the rendering speed starting to slow down?
    Thank you.
    Thank you.
    It depends on what your rendering goals are. Iray (separately from Daz Studio) is constantly being updated to improve what it is able to accomplish in terms of visual realism/complexity on a per-iteration basis, almost always at the expense of slower per-iteration rendering speeds. If you want the most realistic-looking renders (taking advantage of the latest tech advancements therein) you're gonna want the most recent version of Iray regardless of iteration rates. This benchmark/thread is only useful for gauging rendering performance between different GPUs running the same version of Iray. Not the same GPUs running different versions of Iray.
    edited October 2022
    Before 4.20 most of the render times were really about the same with a few exceptions. Each version might add something new, so having a recent version can be helpful.
    4.16 is the last version before they jumped to 4.20. So I would use that one.
    You can also use the beta and directly compare them. So if you have 4.16 on the main branch, you can still have 4.21 in beta form. I think this is the way to go if possible. The betas update more frequently, so you can keep the beta branch up to date for all the new stuff that comes along, while still keeping 4.16 for its pure rendering speed.
    As for the quality of the render...I just don't see a difference in most pics. The only time I see any difference is when ghost lights are involved, and that is a whole thread in itself. If there are any changes to Iray otherwise, they are so subtle most people are not going to spot them without a magnifying glass. And to be perfectly honest, I thought my renders in 4.16 looked better, too.
    But you don't have to take any one's word for it. Since you have 4.16, you have the ability to directly make this comparison for yourself and judge it yourself. You can render the same scene in 4.16 and then 4.21 and see how they compare in both time and quality.
    Post edited by outrider42 on
  • gsil247 said
    I'm strongly considering getting the 4090, and yet I have the 3090. Already been planning how I'm going to get the funds, so by the holidays I should be able to afford it. By then official benchmarks will come out and that will help me decide if its worth it or not. That is probably the only good thing about them being so expensive; time to save and time to think.
    Same here. Already planning out the specs for the system I will build next year. CPU isn't as important to me so will probably get a current gen i5 since I am currently running an i5-6600K BUT I do intend to get the 4090 as well as a beefy SeaSonic 1600W PSU to handle pairing it with my current 3090 and NVLink. Outervision PSU calculator comes out with 1219 W recommended so a 1600W Seaosnic Platinum should do the trick. The room I run my PC in has a circuit that can handle a total of 2300W so I should be able to get by.
