• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Daz 3D Forums > 3rd Party Software > 3ds Max Discussion
Installed but nowhere to be found
Hoplite490Hoplite490 Posts: 111
October 2022 in 3ds Max Discussion
Any idea when this will work? I have tried everything. First, downloaded it from Daz store just to be sure. Next, check Install Manager advanced settings to ensure that the correct path is pointing to Max. Under the Installed tab, Daz to 3ds Max is installed. I uninstalled it and tried again. Daz Central states it is installed and gives me the option to Open but it does nothing. Last, Under Scripts, there is no option for it. Being that I work in Max, I could really use this.
I searched the forums, 3ds Max and Daz to 3ds Max Bridge but nothing came up. Youtube videos make it look so simple but I just don't have the script. How do I get this?
  • frank0314frank0314 Posts: 14,788
    October 2022
    Did you have it installed with DIM and Daz Central at the same time? Did you uninstall one before installing another? Did you add Max to the "Installation" and "Applications" tab?  You shouldn't use both Daz Central and DIM systems. Daz Central is a simplified version of DIM and therefore mostly targeting beginners. DIM is what an experienced user should use because of the numerous capabilities of it and being able to set custom paths. Using both will cause conflicts with the products and things can not work properly. I'm not a Max user so can't comment on the bridge but wanted to point out the "possible" issue(s). Can you possibly show a screenshot of your paths in DIM for us?
  • Hoplite490Hoplite490 Posts: 111
    October 2022
    Attached is a screenshot of my Applications tab in DIM. The installation tab is only for the content path, that is what I always believed.
    1067 x 1051 - 125K
    October 2022
    I have tried previous versions of Max with no success. I realize that in the screenshot that it is 3ds Max 2021 pointing to 2023 but I have many different versions pointing to the correct version installation. This just does not work.
  • vectorinusvectorinus Posts: 142
    October 2022
    Hoplite490 said:
    ...Under the Installed tab, Daz to 3ds Max is installed...
    Installing Daz to Max Bridge means putting Daz to 3ds Max.dsa script in the ".../DAZStudio4/scripts/support/DAZ" folder. Is that file really there?
    June 2023
    I recently built a new computer. Installing Daz to this new computer resolved the issue.
    June 2023
    And what installer did you use? DIM or Daz Central?
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
