Fur outline from Zeus cat not selectable or deletable
in The Commons
I loaded Zeus cat into a scene. With the figure is a white outline of fur that shows up with Zeus, but it doesn't show up anywhere in the Scene tab, Surfaces tab, or anywhere else I can think of. WShen I delete Zeus, the outline remains. What is going on? I'm afraid if I save the scene, the outline will also be saved. All Iwant to do is use Zeus without this fur outline. I provided a screen capture of it.
I'm not seeing this unless I load the Zeus dForce Hair in the Zeus Hair folder. Are you using the preset shown below? It should load the cat base only.
I actually used Sphinx HD under characters. I just put my human character in a new pose, and this happened.
Looks like the fur is parented to the human character. If you expand the character node on the Scene tab you should be able to find it somewhere and delete it.
If you load the cat Actors you can expand their nodes and delete the fur if you want to get rid of it. The cats should be HD themselves as far as I can see (High Resolution under Parameters).
