How to add glossiness to my existing hair?
I want to add a bit of glossiness to one of my existing hair items when I add it to a figure. How to do it?
Once the hair is loaded onto the figure, you can edit reflectivity with the Surfaces tab. For Iray hair, there are multiple sliders and controls, such as "Glossy Reflectivity" and "Glossy Color". You can achieve different effects with this (wet, synthetic material, etc.). Fairly quick and easy to start experimenting with this--Move some sliders, test render, and fine tune for the desired effect.
Top Coat and Dual Lobe Specular are useful too. Both have Reflectivity and other dials that if not already visible will show up when their Weight dials are activated (set higher than 0).
