How do I download DAZ 4.12 or Daz in general
How do I do this? I just got a new hard drive and am not sore how to download 4.21 or anyother daz version.
Easiest way is from your product library: https://www.daz3d.com/downloader/customer/files#prod_13176
@Hughborgsyn_ee7d34a298 Install DIM and Install Daz Studio on a New Computer:
1. Install Daz "Install Manager" (DIM) first, and then you can install and uninstall apps and content from DIM, including Daz Studio.
2. Download DIM: https://www.daz3d.com/install-manager-info -or- (Direct Download Link) https://www.daz3d.com/get_install_manager -or- search for: Install Manager in your Product Library.
3. Install DIM on the C: Drive at its default location.
4. Run DIM, check the box to "Work Offline" (so you can set your Prefs in DIM via the Gear icon) and click the "Start" button.
Input: Name, email and password.
Once DIM is installed, close and re-launch it, and then connect online this time. It will sync with your Daz user account and then you can choose what Apps and Content to install. Select the checkbox for Daz Studio and click "Start Queue". Once Daz Studio is installed, it is best to only use DIM to install content when Daz Studio is not running.
5. In addition to installing Daz Studio 4.21, PostgreSQL CMS Database also needs to be installed through DIM:
https://helpdaz.zendesk.com/hc/en-us/articles/360060104392--Installing-DAZ-Studio-through-Daz-Install-Manager-DIM-
6. Install all the Starter Essentials
7. If you want a custom path to your 3D Content, for example on an External Drive. Enter the path into both DIM (under Installation tab) and the same path in Daz Studio prefs (under Content tab) "Content Directory Manager" (CDM).
