DIM Error on Raven Woman Outfit Bodysuit
In DIM and trying to download today's bundle. This one item fails download immediately. Everything else downloads fine.
Log:
2022-10-07 07:57:55.571 [WARNING] :: Download Error: IM00087268-01_RavenWomanOutfitBodysuitforGenesis8and81Females.zip : Error setting up download file
2022-10-07 07:57:55.571 [WARNING] :: Network Error: : Operation canceled
2022-10-07 08:03:23.898 [WARNING] :: Download Error: IM00087268-01_RavenWomanOutfitBodysuitforGenesis8and81Females.zip : Error setting up download file
2022-10-07 08:03:23.899 [WARNING] :: Network Error: : Operation canceled
2022-10-07 08:16:09.112 [WARNING] :: Download Error: IM00087268-01_RavenWomanOutfitBodysuitforGenesis8and81Females.zip : Error setting up download file
2022-10-07 08:16:09.112 [WARNING] :: Network Error: : Operation canceled
This is still broken...
Clicking on info in DIM leads to a completely different product: http://docs.daz3d.com/doku.php/public/read_me/index/87238/start
Both products have the same number though, 87238.
While the actual product is https://www.daz3d.com/downloader/customer/files#prod_87268
Sorry, I was waiting for verification from another user. That ended up being me, so it has now been sent in though it may not get fixed over the weekend.. DIM is too slow to check this has worked, but a manual download did appear to snag the correct file and that can be dropped into the DIM downloads folder - though you may need to work offline in DIM for it to show (otherwise it may see the wrong file on the server and since they are different assume you need to downlaod the "update").
Thanks. I didn't have time to investigate this until the end of my day anyway. I wasn't sure if it was just me before noticing the number mismatch.
I am told this should be fixed, I haven't started DIM to check (it's on an external drive and takes ageeeees to load)
Just tested it. It's working now. Thanks!
Thanks for confirming.
