Ah Hahahahah, (or how I finally converted dForce hair into Strand based)
At long last, I've managed to export dForce hair out of Daz and then convert to strand-based geometry.
And as it turns out I had the tools for some time. But, for the lack of documentation and their being poorly named (sound familiar), I simply didn't know I had them. Or rather what one in particular actually did.  Asked a number of times if something like that existed, and nada. Crickets.
Required the use of two separate products but that's not really the point. Results are.
  • How'd you do it?
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,250
    edited October 2022
    you don't name the products but I don't own anything extra and can do it
    the results are ridiculously heavy though
    not sparse like yours unless that's the hair you wanted
    just use line tesselation and PBR preview
    for creating geometry by exporting an obj that is
    but if you mean strandbased in DAZ studio, curve based editable by the strandbased editor formerly Garibaldi hair, no, I don't know how to do that
    I can make it curve based in other softwares
    not really sure what you mean TBH as the post very vague
  • PendraiaPendraia Posts: 3,609
    Sounds interesting...any chance of a tutorial for dummies like myself who haven't played much with strand hair?
    thanks!
    Pen
  • I've done that for years.
    I print it out and use a pencil, and then scan it.
    No one will ever know.
    Well now, we will :-)
  • Oops.
  • Doc AcmeDoc Acme Posts: 1,153
    As I take me assets into Lightwave, I'm not sure how much of this will help.  However, I've heard that the key tool which is to convert OBJ curves into open curves, is available in Blender.  I don't use Blender so some else perhaps knows details.
    The second step is select ALL of those curves and Profile them.  That is, using a 1D or 2D shape along the length of the curve and defining a starting & ending size in diameter. Again, I don't know what tools are available outside of Lightwave.
    I've a number of animals using dForce fur I hope to convert.
  • jag11jag11 Posts: 885
    edited October 2022
    There is another way within Daz Studio but I think that option is in its infancy (might be also abandoned) and there is no documentation about it. Dates from version 4.12
    There are two mysterious options, "Convert Ribbons to Lines" and "Convert Tubes to Lines" under the Edit > Object > Geometry menu.
    I applied it to Morley Hair and this is what I got:
    462 x 600 - 279K
    Post edited by jag11 on
    tessellation modifier (generates geometry for renderers that cannot handle curves) already does this... choose the number of sides... export
    Much of Daz is mysterious, but I will check that out.
    Guide hairs have more going on that I need to explore.  AM has a new LAMH in the works.
    Tnx
  • A guy asked if I knew where he could find some hair; I said, "Sorry, not off the top of my head."
    I'll look into that Richard.  The guides might be useful to me as is.
    Ta dum. <rimshot>
