Cannot login to the documentation center
vintorixvintorix Posts: 220
edited March 2015 in New Users
Why am I denied access to the documentation center? It says "login" but my daz account (which I am writing under now) do not work.
Link to page, http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/interface/panes/script_ide/execute_button/start
Post edited by vintorix on
  • StargazeyStargazey Posts: 274
    It looks like you're trying to access an area which is not available to the public. If you want the Reference Guide try a shortened version:
  • vintorixvintorix Posts: 220
    Thank you but as you can see it is the same link -I have to manage somehow..with or without docs.
    It does say that particular link is a WIP, ie Work In Progress.
    "It does say that particular link is a WIP, ie Work In Progress."
    That doesn't mean much WIP is slapped down on almost everything I am interested in but you are not denied access because of that-
    And another thing, this has happened once before, when I wanted to have a look at the Measure Metrics doc before ev buy. But the next day it was suddenly open. It would be nice if someone could shed some light on this.
  • fixmypcmikefixmypcmike Posts: 19,707
    It was probably being worked on when you tried to access it. Is it available for you now?
  • namffuaknamffuak Posts: 4,455
    I ran into this a while back - it seems like a certain level of documentation on the hows and whys is locked. I was chasing through the shader mixer documentation and all of a sudden the next level of links all gave me the 'forbidden' screen. I'll give it a try again tomorrow and see if it's still locked.
    edited March 2015
    "It was probably being worked on when you tried to access it. Is it available for you now?"
    Yes, but the script documentation is still locked. Being worked upon is the most likely explanation but why not say so, "under construction"? instead of this rather sinister denial. So you avoid wasting half an hour trying to find out how to register.
    There are plenty of live links, even on the page the OP linked to
