Something strange
Hi,
I've the same amount of data, scene I've created are fine but my people folder is empty, how can it be possible ? Probably the fact I've got 2 external SSD, one for production and one for backup, sometime it's named one or other E or F (depends on the order I connect them), is this the problem ? The stangest thing is : in my production ssd, no data loosen and ancients scenes ok even if the backup disk is not connected
Thanks
Yes, that is the problem. You need to either change the drive name or edit the known content folders in DS to match the drive names.
Ciao
TD
thanks to confirm !
You can assign permanent drive letters to removable drives:
https://www.windowscentral.com/how-assign-permanent-drive-letter-windows-10
