Daz to Max Bridge
Hoplite490
in The Commons
Any idea when this will work? I have tried everything. First, downloaded from Daz store just to be sure. Next, check Install Manager advanced settings to make sure that the correct path was pointing to Max. Under Installed tab, Daz to 3ds Max is installed. I uninstalled and tried again. Daz Central states it is installed and gives me the option to Open but it does nothing. Last, Under Scripts there is no option for it. Being that I work in Max, I could really use this.
I searched the forums, 3ds Max and Daz to 3ds Max Bridge but nothing came up? Youtube videos make it look so simple but I just don't have the script. How do I get this?
I'd recommend installing either through DIM or manually from the GitHub. Have you looked in the 3DS Max subforum? You'd be more likely to get a helpful response there.
3ds Max Discussion - Daz 3D Forums
