Outfit(s) that can be used for Stargate uniforms?
Having 'kitbashed' a Stargate Command MP car, I'd like to be able to outfit its crew to match, but I'm not having a lot of luck. I specifically want to replicate the black uniforms of the later Mitchell years, but I don't need the tactical vest and weaponry - just the jackets and suitable pants and boots. Any suggestions?
  • GordigGordig Posts: 10,622
    MI Tactical seems like a pretty good starting point.
    Technically the black uniforms of Mitchell years is the same as the earlier seasons, they just switched the color from Sage Green to Black.
    For boots and pants it isn't too hard as they are typical Combat/Duty boots,and either OG-107 or BDU pants. So any modern Soldier outfits should work. The problem is the jacket, as it was a somewhat custom design based off the WEP jacket, so unless you commission some one to make it, you will likely never find the exact jacket for Daz Studio. Linday did the M65 and MA-1 jackets for Genesis 3, but I've never seen a Daz Studio version of the WEP. (Not that it ever really made sense a largely USAF based organization wearing the WEP jacket, it would have either been the M-65, or MA-1, or just typically BDUs without an outer Jacket) Though even at the times the SG-1 crew wore BDUs they weren't typical BDUs, they had the lower Jacket pockets removed, and added epualets or they may have even used the older OG-107 fatigues and had them produced in Sage Green. I can't remember if the buttons on the uniform jacket was covered or not. (If OG-107 based the buttons are visible, BDUs would have a flap covering the buttons)
