Measure Metrics
Hi,
is there a tool in Hexagon similar to measure metrics in DAZ Studio?
Or maybe a plug in or external program?
Thank you
Hi,
Thank you
Well, there's a setting for the grid, think it was Edit > Preferences ... somewhere there's a place to set the thickness of lines, size of dots and the spacing for the grid lines. I use the default sizes there. An .obj file export from D/S at Poser settings, imported into Hexagon using 1 m settings works. Then exporting out from Hexagon using 1 m settings and importing into D/S at Poser settings.
Some make a prop and import that into Hexagon for use as a measuring item.
http://www.sharecg.com/v/69559/related/21/DAZ-Studio/Measuring-Wall
I use Slosh's "Measuring-Wall" all the time now, but I've made a sort of building scene with it. In the scene I have the wall plus a 12" ruler and a Reference Picture master. So I just change the Reference and scale it and use either Slosh's wall or the ruler to get the scale right.
