Does anyone know what schoolgirl (double pigtails) hair product is used in P3D Fabienne promo?
pds
in The Commons
The hair in question is from the 7th promo image (not counting the main promo). I have tried searching here and at the other place, but struck out. Granted, search here is still hit or miss...
https://www.daz3d.com/turbulent-pigtails-hair-for-genesis-8-and-81-females
The ones there are really long but maybe there is a morph (or hand editing in the settings) for the length.
Tizzalicious did a render here: https://www.daz3d.com/gallery#image=1239656 using them shortened....
Original product:
https://www.daz3d.com/p3d-fabienne-hd-for-genesis-81-female
Thank you for such a quick reply. I saw those, but based on the hair ties and the description wherein Outoftouch says, "Please note that this hair is created to be long. You will get a couple of morphs to shorten the pigtails and/or the front, but even with these options applied, the hair will still stay relatively long..." I figured it was a different product than what P3D used. Definitely looks very similar. I don't know how easy it would be to edit the geometry of the OOT product to get the tails to shoulder length or shorter, but it might work.
Read the description? ME??? :D something I definitely should do more often as I have been surprised more than once both good and bad because I saw the promo and straight to cart. Could be something from the other store and the bands look a little bit different but wasn't for sure if it was because the promo size was small. As far as the length- because she DOES have length modifiers I would assume you could turn off limits and keep going as short as you like. The pigtales in P3d definitely don't look as thick so maybe that is why there is a note in the description? (Though I think it looks a bit more realistic in P3ds assuming it is the same). At least it is currently on sale and if you hate it you can always get a refund but hopefully someone else can chime in and confirm or give you the right product. Good luck, hope you find it/one that works!
I did see that the OOT product is currently on Flash Sale and debated picking it up to test shortening the tails...I just hate having to return stuff =D
Might be https://www.daz3d.com/double-tails-hair-for-genesis-3-and-8-females
That's it! Thank you! Bummer I missed the Flash Sale for it, but I've wishlisted the item. I saw the main promo for the Double Tails hair but was thrown off by the braided tails and didn't look closely enough to see it came with multiple "tail" options.
"There's always another sale" (TM) :) Glad I could help..
haha, yes, you are right about that. I'll try to catch it at the next sale opportunity.
