All morphs for all content suddenly gone
SJN0001SJN0001 Posts: 3
edited September 2022 in Daz Studio Discussion
So I was messing around in Daz just now, doing poses as normal, went to check a render real quick, closed it, went back to Daz and all my morphs were suddenly gone, followers in the Parameters pane are in italics and inaccessible, and I don't know what happened.
I have Show Hidden Properties checked in the Parameters tab as well as Display Separate Items and Display Followers, nothing is locked, I haven't moved my data folder or changed anything with the library settings. I've tried other files, starting new files with the base Genesis figure, I've tried rebooting, and it's still not working.
I've attached screen shots. Thanks
Post edited by SJN0001 on
  • MelanieLMelanieL Posts: 7,789
    The first screenshot, you appear to have the figure selected. The second (without the morphs and pose controls) you appear to have selected the hair - I guess that hair doesn't have morphs/pose controls? Select the figure again and your morphs should appear again.
  • Yes, the first image is the figure, the second is the hair, but the hair did have morphs before, and selecting other things then the hair again doesn't change anything
    Oh, that is odd. Can you check that the morph files still exist on your computer - according to the ReadMe you should be able to find them here (three examples):
    • /data/second circle/SC Ana Hair/SC Ana Hair Rigged/Morphs/second circle/SC Ana Hair/Back Out.dsf
    • /data/second circle/SC Ana Hair/SC Ana Hair Rigged/Morphs/second circle/SC Ana Hair/Back up.dsf
    • /data/second circle/SC Ana Hair/SC Ana Hair Rigged/Morphs/second circle/SC Ana Hair/Behind Shoulders.dsf
    Can you find them there? If not then a reinstall of the hair might be a good idea.
    (If you install through Daz Central or DIM, that data folder will be in your main content library). If you installed with Daz Connect (i.e. from inside Daz Studio) then they will be a little harder to find.
    Edit to add: I'm sorry, I just noticed the time and need to go now. If noone else drops in to help then I will be back tomorrow.
    Post edited by MelanieL on
  • SJN0001SJN0001 Posts: 3
    All the morph files are there, but it's not just that hair, but all figures, objects, everything, even just base Genesis 8. I can look through the content library and load new figures/props/etc. but they all come out like that
    edit: Just uninstalled and reinstalled Daz, nothing
    For reference, attached is what I get in the parameters pane when I just load base Genesis 8 and nothing else
    Reinstalled the CMS and Genesis 8 Base from DIM, still nothing
    edit: Uh, just started working correctly again, not sure what happened. Maybe the CMS needed time to refresh, I don't know
    145 x 265 - 9K
  • Is there anything in the filter text box?
