[Solved] How to replace uv map?
JamesJames Posts: 1,177
edited September 2022 in Daz Studio Discussion
The position of my cloth uv map change a little bit.
So I need to replace the one in DAZ.
Can it be done?
I tried load uv set. Not working.
Post edited by James on
  • felisfelis Posts: 5,945
    If you have UV unwrapped the item in another program you can load UV and point to that, and then the item should have 2 UVs, where you have to select which to use.
    You cannot change the UV layout within Daz Stidio.
  • JamesJames Posts: 1,177
    Can I delete one?
    Not that I am aware of. Although I have never really considered it.
    Why do you want to delete a UV map?
  • If it is only the UVs that have changed then Edit>Figure>Geometry>Update Base Geometry should do the job.
    @felis
    I did "load uv set" several times.
    @Richard
    Thank you. That does the trick
