[Solved] How to replace uv map?
James
The position of my cloth uv map change a little bit.
So I need to replace the one in DAZ.
Can it be done?
I tried load uv set. Not working.
Post edited by James on
If you have UV unwrapped the item in another program you can load UV and point to that, and then the item should have 2 UVs, where you have to select which to use.
You cannot change the UV layout within Daz Stidio.
Can I delete one?
Not that I am aware of. Although I have never really considered it.
Why do you want to delete a UV map?
If it is only the UVs that have changed then Edit>Figure>Geometry>Update Base Geometry should do the job.
@felis
I did "load uv set" several times.
@Richard
Thank you. That does the trick
