How can I make this materials on my model? Iray WetFX 2
foxyfoxfurries
Hey , I bought the item Iray WetFX 2 and I saw you can change the wet on the model and also make some more things that can be looks wet shirt or some blood for fights. Iray WetFX 2 | Daz 3D
But dont have there explain how to do it , any one know how can I use it?
I did the wet body but I cant see how I cant make it less wet , and in the picture they give have 3 diffrent styles. Thanks! :)
I just went through the product so....
the product consists of
Yes I saw it but In the pictures he show that I can use it like blood on my model , I mean need to be prop for that no? or I need to buy something extra for that?
There is a wearable decal which can be loaded and positioned so it glances against the skin (it loads to the center of the figure so it must be repositioned) and it has a blood material. That is not the geoshell.
Oh ok thank you but I don't find how can I do it , it like put some prom on my model and then just move it with some side option?
I made an image showing the proper placement of a decal here: https://www.daz3d.com/forums/discussion/571336/tatt-s-all-folks-placement-issue
Ok thank you I understand , so its not easy to do , I mean I dont know how to make a lot of things in this software , most of the time I just use my stuff as a prop and then move it , in what I bought I can't do it easily and just how you do it?
Oh, I was going to say that it is easy to do. Apply the decal, apply the material settings to the decal (color and splash style), use the left or right camera to see the figure from the side, and finally use the Parameter settings to move the decal out of the center of the figure to a place where it just grazes the surface. All of this can be done in less than 30 seconds.
@nemesis10 Great Examples of applying decals to a figure. Here are a few additional tips that first-time users of Decals may find helpful...
1: Sometimes you first need to Parent the decal to the figure or object you want to apply it to.
2: Always make sure that the surface you're projecting onto is within the decal bounding box.
3: When selecting the decal bounding box with the translation tool, the "direction" of the decal is always opposite the direction of the blue arrow (Z-axis).
4: You need to be in the Nvidia Iray Viewport mode to see the Decal effect (turn on the NVidia preview option).
Thanks to both of you!!!! I created Decal on my model and put the metirial and it worked! looks nice but hard to see if I do Invidia Ray its popping but it works well when I rendeting it haha.
BTW can I use it on stages? like boxing ring? or only on models?
Have some more idea for some nice blood for fights? or something that good for it in shop? thanks!
@foxyfoxfurries You can pretty much use a Decal on any surface, object, figure, etc. Here's how...
1. In the Scene tab, select the object (ex. boxing ring floor/stage floor or wall) that you want to apply a decal to.
2. Go to the menu bar: Create-->New Iray Decal Node and select the radio button for "Parent to selected item"
3. Click OK and the bounding-box for the decal will appear in front of your object... Move it just in front of your object (almost touching)
4. In the Surfaces tab, go to "Base Color" and select the down-arrow to browse to your desired Decal image and choose it from your hard drive.
5. If you need part of your Decal to be transparent (such as the background), make a Mask for it in a paint program, then in Surfaces go to "Cutout Opacity" click the down-arrow and select the mask (make sure the Cutout Opacity slider is at 1.00).
6. Position the decal as desired.
7. After applying the decal, you can go to Surfaces tab and turn down the Cutout Opacity for more translucency, and adjust the Base Color, and Emission Color.
NOTE: In Parameters tab, you can change "Projection Type" from Planar (Flat) surface to Sphere, Cylindrical, etc.
In regards to Blood Decals in the Daz shop... check-out some of these products:
Iray GrungeWorx
Dega Extreme Wound Decals
Iray Clothworx
Wound Makeup Artist for Genesis 8
