Alembic Exporter: THE INSTALLATION PATH FOR DAZ STUDIO COULD NOT BE FOUND!!!
Hey guys, I tried so many times but didn't work, what should I do?
  • How are you installing? Did you use the same method for Daz Studio and for the plug-in?
  • 理查德·哈塞尔廷说:
    你是怎么安装的?您是否对 Daz Studio 和插件使用了相同的方法?
    Can you see my pictures? Upload failed maybe. image image image
    I installed "DS4_Alembic_1.4.0.123_Win64.exe" and "Next Next Next", then info window: "The installation path for DAZ Studio could not be found. "Alembic DS4 (64bit)" connot be installed. Setup will now quit." It's failed.
    And I tried to this way, but it is failed too:
    "Some people have Windows bug and daz3d registry issues. Also keep in mind this is for 64bits only.
    If you encounter "can't find path..." error, do the following steps:
    1. Run regedit.exe
    2. Under "HKEY_CURRENT_USER\SOFTWARE\DAZ\Studio4", add an string type(REG_SZ) key: InstallPath-64
    3. Set key's value to the DAZ installation path (for example: "C:\Program Files\DAZ 3D\DAZStudio4")
    4. Close regedit, and install Alembic Exporter
    5. Launch DAZ Pro, goto Help -> About installed plugins and find Alembic Exporter
    6. Enter the serial number, restart Daz."
    Sorry, I am not good at English, but I failed again and again, so I'm here, hope you could understand :(:(:(
    654 x 425 - 71K
    1290 x 149 - 25K
    462 x 54 - 6K
  • Did you use an .exe file to install Daz Studio, or did you Daz Central or Daz Install Manager?
    Do you have non-US characters in the path where Daz Studio is installed?
  • 理查德·哈塞尔廷说:
    您是使用 .exe 文件安装 Daz Studio,还是使用 Daz Central 或 Daz Install Manager?
    Daz Install Manager
  • frank0314frank0314 Posts: 14,733
    edited September 2022
    Take a look at the documentation for that plugin and see if it will help you at all. I'm unfamiliar with it so not sure if it will help at all. Did you try to reinstall it at all? Can you post a screenshot of you "Applications" tab inside DIM (Daz Install Manager) which will be located in advanced settings when you click on the cog wheel in the upper right hand corner of the screen? If you right click on the product in the installed tab select "Show Installed Filess", can you post a screen shot of that as well?
    Post edited by frank0314 on
  • If you installed the application through Install Manager then you should also install the plug-in that way. Mixing methods can lead to the kind of problem you are having.
